| G-Code Programing Discuss G-code programing and problems here! |
Ok, I need help in regard to clarification of these codes- G112, G17, and M119 S... i run a Daewoo Puma 2000sy machine. Full c axis and y axis on main and sub spindle. I use mastercam to do all of my code. When I do something like engraving on the face of a part the code I get uses g17 before engraving and back to g18 at the end of the operation. Everything is fine. I never have seen a g112 post from my mastercam parts. What is the difference between g17 and g112? Are there applications where one is used and not the other? I am hoping someone can give me a brief description of c axis ops using these codes. Also, how does m119 fit into the mix. I have never seen this one either. I understand you can position the spindle to a specific C axis rotation with this command. How is M119S0 different than just commanding G00C0.0? If I just call out C commands is that not the same as m119 positioning. Everything I have used up to this point is either in g17,g18,or g19, and I am the only cnc person in my shop. Any help will be much appreciated. TY, Chris |
| g112 and 113 are polar interp commands. g17,18,19 are plane commands. the best i can remember daewoo uses g112.1 and g113.1 . I always call a C0. after G112.1 comes active since some post dont go back to the same spot after a tool change. as far as the m codes go i cant realy remember since there are 300+ on that machine and i dont have a book in front of me. |
| With your Puma SY you have a couple of choices when working on the face of the part with live tools. 1. X/C - contours are broken into little line segments. 2. X/Y - programmed just like a mill, except X is a diameter. Requires G17 (XY Plane) if you're going to use cutter comp and/or cut any arcs. 3. Polar - program like a mill except X is a diameter and you use C instead of Y. G12.1 turns on Polar Interpolation (G17 isn't required, IIRC). Cutter comp works in Polar Interpolation mode. X/Y is probably the strongest (if the part fits within the X/Y envelope), because you can clamp the C-Axis and go to town. X/C or Polar Interpolation require C to be moving, so you can't use G89 (High Clamp). M119 simply orients the spindle to the specified angle (S). IMHO, the best use for M119 would be for robotic load/unload applications, but others may have different ideas. |
| dcoupar, Ty for the info. I think I will stick with the way I have been doing it which is clamping and using X and Y axis as you said. I think you are right as far as the rigidity of this setup is concerned as long as you can fit within the y max travel. I appreciate your input. I was just getting a bit confused with people talking about g112 and I thought I was missing a piece of the big picture. I have had problems in the past with trying to use X and C where the C motion could not keep accurate enough in its feed, delivering out of tolerance parts. Especially when helical boring. I would get out of round holes using X/C and perfect ones using X/Y. Thanks again. Chris |
| g02 g03 explanation | valmet58 | CNCzone Club House | 4 | 03-19-2008 09:36 PM |
| I need some explanation | grebator | Stepper Motors and Drives | 0 | 04-04-2007 07:03 AM |
| G64 & G61 Explanation Please | weaston | G-Code Programing | 1 | 01-31-2007 04:34 AM |
| Need explanation of 5 microstep | keithorr | Gecko Drives | 2 | 03-22-2006 04:57 PM |
| CNC explanation | Alex S.A | General Metal Working Machines | 2 | 10-01-2004 12:23 PM |
