Old 02-20-2008, 09:34 AM
EvanZ is on a distinguished road
LATHE GCODE
Could someone loan me a Gcode for turning. I want something I can load into Mach3 Turn just to play with it a bit. I'm not going to actually cut. I just wanted to play with the software before the lathe is done. Thanks Evan
Evan.
"You're making WHAT?"
Old 02-21-2008, 05:05 PM
compuslave is on a distinguished road
You mean just quick program?
If your stuff will read standard Fanuc I'll give you one.
G00 X2.1 Z0 M8
G01 X-.032 F.008
G00 X2.1 Z.1
G71 P1 Q2 D.1 F.014 U.02 W.002
N1
G00 X.94 Z.1
G01 Z0 G42 F.008
X1.0 Z-.03 F.003
Z-2.0 F.008
X1.94
X2.1 Z-2.08 F.003
G40
N2
G70 P1 Q2
G00 X2.1 Z.1 M9
X20. Z20.
M30
Enjoy.
Old 02-21-2008, 06:42 PM
jhowelb is an unknown quantity at this point
Run Mach# Turn and use the wizards on the screen. There is all the gcode you could want.
O.D., I.D., convex, concave, grooves or threads!!!
"Error of Opinion may be tolerated where Reason is left free to combat it." - Thomas Jefferson
Old 02-25-2008, 11:38 AM
adamant is on a distinguished road
Actually I'd like a good simulator to check programs as well. I left a shop that had graphics for all their machines so I could check the programs before the run and ended up in a shop that has no graphics for the machines.
I had a G2 and G3 misplaced and made a bad part. I could have avioded this if I had graphics or a simulator of some sort.
Old 02-25-2008, 04:21 PM
Seems like a backwards G02/G03 would throw an alarm since your endpoints would be off by at least the radius amount. Look at predator's software. Just google 'Predator editor'
Old 02-26-2008, 09:25 AM
Andre' B is on a distinguished road
In some canned cycles you will get an error for nonmonotonic direction on an axis but for a simple tool path swapping G2 and G3 you just go the other direction around the circle.
DXF -> Gcode (lathe) Gujustud General CAM Discussion 3 08-24-2010 08:28 AM
Gcode frankg521 General CAM Discussion 24 08-01-2007 12:02 PM
Shoptask CNC Lathe and Mach3: Gcode delima KaptainKarst Shopmaster/Shoptask 20 08-05-2006 05:55 PM
I have a problem with my gcode or my conversion to gcode , everything is tiny? NickLatech G-Code Programing 0 03-10-2005 12:46 PM
gcode to gcode converter july_favre General CAM Discussion 4 05-24-2004 06:51 PM
