Results 1 to 6 of 6
Thread: G84 (ridgid tapping) on Mitsu 50L controller
    Registered Chuck Reamer's Avatar
    Feb 2007
    Great White North
    I have a Daewoo Lynx with a Mitsubishi M50L controller, I am trying to rigid tap a 1/4 NPT, 18 TPI.
    The material is Delrin (Acetel), and im going super slow just to prove it out. Here is what I am running for a program right now.
    G54
    T0202 (1/4 NPT TAP)
    G50S100
    G97S25M3
    G00X0.0Z.1
    G84G98R.1X0.0Z-.5F1.3888
    G40
    G99
    G28U0.0W0.0
    T0200
    M30
    I have tried to run the feed in inch per rev and the results were worse, so I am running IPM. Its close, but still seems to strip out the threads.
    Anyone have any ideas on this?
    Live free or die
    Dec 2003
    I don't know whether it will make a difference, but I suspect you do not need the G98, the G84 together with the F value should synch the spindle encoder/speed.
    Apr 2007
    Quote Originally Posted by Chuck Reamer View Post
    G54
    T0202 (1/4 NPT TAP)
    G50S100
    G97S25M3
    G00X0.0Z.1
    G40
    G99
    G28U0.0W0.0
    T0200
    M30
    Your tapping at way too slow of an rpm. If the speed is to slow some controls get jittery in syncing the axis and spindle speeds. I try to never rigid tap at anything less than 250rpm, I mostly tap at 500-1000rpm, 500 rpm for larger course threads and 1000rpm for the smaller finer threads. Try changing your rpm to 500 and your feed rate to 27.7777 ipm. Are you using coolant? Just some thoughts, hope this helps.
    Feb 2008
    I was looking at your program and I would take the "M03" out and go back to a G99 . And I'm not sure how you came up with the feed for that tap. Your feed for a 1/4 pipe should be ".0555" The G84 will start the spindle. But it won't start until the tap is almost to the part. If you get an alarm there are four parameters that need to be changed. I just went through this problem on a brand new Mori Seiki NL2500 with a Mitsubishi control.
    Registered cnc-king's Avatar
    Jul 2003
    united states
    G54
    T0202 (1/4 NPT TAP)
    G50S100
    G97S25M3
    G00X0.0Z.1
    G40
    G99
    G28U0.0W0.0
    T0200
    M30
    G54
    T0202 (1/4 NPT TAP)
    G50S100
    G97S25M3
    G00X0.0Z.1
    M29S******
    G80
    G99
    G28U0.0W0.0
    T0200
    M30
    our daewoo requires a m29 with the spindle speed before the g84 line to activate rigid tap, per the previous reply your you are better off tapping in IPR letting the machine calculate the feed from the programmed RPM
    If you can ENVISION it I can make it
    Feb 2007
    Great White North
    Thanks CNC king i will give that a try
    Live free or die
    1. Replies: 10
      Last Post: 03-17-2008, 01:42 PM
    2. MITSU. 520 L CONTROLLER QUESTION
      By BAD DOG in forum Daewoo/Doosan
      Last Post: 02-08-2008, 04:00 PM
    3. Ridgid Tapping on Haas
      By Shotout in forum Haas Mills
      Last Post: 08-01-2006, 10:40 PM
    4. ridgid tapping with servos
      By miljnor in forum Servo Motors and Drives
      Last Post: 09-21-2005, 02:35 PM
    5. Mazak/Mitsu servo controller issue
      By carbidecraters in forum Servo Motors and Drives
      Last Post: 07-27-2005, 05:20 PM
