Results 1 to 7 of 7
Thread: G code problems, any help appreciated
    Feb 2006
    fulton
    I have built an operating "joe's 2006 model" and am using mach3 software.I just cannot my dxf drawings to G code ,some direction would be appreciated .
    My current project involves sinking several "pockets",I think thats the term,into a lumbercore drawer bottom. The pockets house butlers tray hinges. I have included a drawing showing the shape of the pocket. the hinges are 3" long and 1 1/2" wide, they are not oblong but have semicircular ends [1 1/2" radius] any would be appreciated...regards mike hide
    Attached Files Attached Files
    Mar 2003
    Shelby Twp, MI....USA
    What are you using to convert them? LazyCAM? You might want to tru the demo of SheetCAM and see if it does what you need. Not as cheap as LazyCAM, but it'll work.
    One thing I noticed is that you need to work on your CAD skills. If the hinge is 1-1/2" x 3", then shouldn't the radius be 3/4". I drew what I think is the correct size and added it to your drawing.
    Feb 2006
    fulton
    Thanks Ger .Point taken regarding my CAD difficiencies. Yes I have been trying lazycam with very little luck. As you suggested I will give SheetCAM a try and see if I can get that to work. If It works I will see about purchasing it.
    I have spent considerable time developing Gcode for some items and realize as a novice it is very time consuming and requires absolute accuracy if a perfect item is required on the first try......thanks again, regards mike hide
    Registered Barry_ward's Avatar
    Apr 2006
    USA - Atlanta
    CAD Help
    Mike,
    I don't know about your converter, but your dxf likely needs to be closed so the converter can make the pocket.
    In your DXF the top line is not touching either arc.
    You will also likely need to move the location of the pocket to 0,0,0 for convinence in setting up the job.
    Your location says Fulton. If that's Atlanta, send me a PM and I might be able to help you in person.
    Barry
    my projects:
    http://www.barryfish.com
    Feb 2006
    fulton
    Thanks for thw reply . Yes I am in the Atlanta area and very new to this subject . I live about a mile from Lennox square [the place where my wife spends all our money].
    Ger kindly corrected My CAD difficiencies and posted a good CAD drawing and suggested using EdgeCAM.I am downloading the trial version now.
    I have been operating on my own from the start on this project so if you are in the vicinity at any time I would be pleased to meet with you.I have never used the messenger thing so I am going to have to get my daughter to help on that [the local computer genious.....regards mike hide
    Mar 2003
    Quote Originally Posted by mike hide View Post
    That was SheetCAM, but I think you just mis typed it.
    Feb 2006
    fulton
    Sorry about that Ger I should have typed SheetCAM......mike hide
    1. Lcam G-code posting problems
      By Holescreek in forum Mach Wizards, Macros, & Addons
      Last Post: 01-06-2008, 02:31 PM
    2. Having problems posting code.
      By Stampede in forum BobCad-Cam
      Last Post: 10-27-2007, 12:18 PM
    3. Catia NC code generation problems
      By phoenix2212 in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 08-19-2007, 06:31 PM
    4. Help - Problems with Z coordinates in g code
      By Socalsurferx in forum G-Code Programing
      Last Post: 03-12-2006, 05:12 AM
    5. Problems running G-code
      By milgo in forum Mach Software (ArtSoft software)
      Last Post: 10-31-2004, 11:27 AM
