| G-Code Programing Discuss G-code programing and problems here! |
Having trouble getting this cycle to run, machine keeps giving me a "#10 bad g code) error. Anybody see any problems here? My tool block: T1010 S1500 M03 G00 Z.1 G00 X0 G83 Z-3.0 R.100 P0 Q1000 F.006 G00 G80 Z.25 G28 U0 M30 FYI - Parameter 5101, Bit 2 = 1 (I guess this is the parameter that determines if the peck is high speed or regular.) Thanks! |
| get rid of the P0 or at least assign a value to it for the drill to pause at the bottom of the hole, that is where your error is coming from. had the same problem on a daewoo s2000sy
__________________ If you can ENVISION it I can make it |
R is the distance from the start position wich is Z.1 So it will retract to Z.2 with a R.100 with the intial Z set of .1 set R0. and it will use the Z.1 as the retract plane. let us know what you figure out. I run a 18-iTB lathe my self. |
#10
| What does your manual say about the alarm? We have a few Tsugami's that don't have enough memory on the backside so we have to change the depth of cut. I'd start messing with the values just to see if it'll run. |
#12
| Try this------i found drilling cycles or can cycles on lathes--always where unreliable so this way you make your own-have a good day (DRILLING) G00G28U0 T1000 G00T1010X0.0Z1.0S1500M03 G00Z.1 () #10=31 (===3.1--IN/.1 TRAVEL) WHILE[#10GT1]DO1 G01W-0.1F.006 (G04 X1.0) (ENTER DWELL IF NEEDED) G00W.2 G00W-.2 #10=#10-1 END1 () G00Z.25 G00G28UO M30 |
| Peck driling on spade drill? | cijunet | General Metalwork Discussion | 4 | 12-09-2007 03:29 PM |
| Bridgeport DX-32 Torq-cut 22 peck drill problems | RedGTZ | Bridgeport and Hardinge Mills | 5 | 02-01-2007 11:47 PM |
| Peck Drilling on a Fanuc 0i Mate TB.... | Darc | Fanuc | 9 | 10-27-2006 07:51 PM |
| fanuc -om peck cycle | PETE1968 | Fanuc | 4 | 04-05-2006 09:57 PM |
| G83 peck Drill cycle | Vaughan | G-Code Programing | 24 | 03-19-2004 11:11 AM |
