| G-Code Programing Discuss G-code programing and problems here! |
I was reading in my manaul today that I should use G85 for a canned boring cycle. I have a leadwell LTC-15 with a fanuc O-T controller. As I read on it said at the bottom of the hole there will be no spindle rotation. If Im not mistaken, shouldn't it still be spinning at the bottom of the hole? Besides that, I just wanted to make sure I was using the right code. Could I get an example of a quick canned boring cycle? Thanks a lot. |
| G85 (feed in - feed out) and G89 (feed in - dwell - feed out) don't stop the spindle at the bottom of the hole. G86, G87, and G88 do. Here's one example: N03 G00 G40 G80 G91 G28 Z0 (SAFE START) T03 M06 (TOOL CHANGE) G54 G90 X1.0 Y1.0 S2000 M03 (POSITION X, Y & START SPINDLE) G43 Z0.1 H03 M08 (APPLY TOOL LENGTH COMP & COOLANT ON) G85 Z-1.0 R0.1 F10.0 (BORE HOLE 1" DEEP AT CURRENT X,Y) X2.0 Z-1.25 (BORE HOLE 1.25 DEEP AT X2.0) G80 M09 (COOLANT OFF) G91 G28 Z0 (ZERO RETURN Z) M01 (OP STOP) Remember, CNC programming is like skinning a cat. There's more than one way to do it, and your machine may not use this exact programming format. |
| different peck cycles? | C5turbo | Fanuc | 9 | 11-06-2008 05:03 AM |
| canned cycles on 16t? | DocHod | Fanuc | 3 | 07-08-2007 07:58 PM |
| G90/G91 in canned cycles | alfalfa | CamSoft Products | 18 | 02-25-2007 05:20 AM |
| Mill cycles or Operations | camtd | EdgeCam | 3 | 10-20-2006 12:38 AM |
| canned cycles on Haas | GITRDUN | Haas Mills | 3 | 09-21-2006 07:58 AM |
