Old 01-15-2008, 12:03 PM
Mitsui Seiki's Avatar
Mitsui Seiki is on a distinguished road
Lightbulb Post a sample of the program.
I have seen many posts where people are having problems with programs.
The machine does this and that when it shouldn't.
Why not make it a habit to post a sample of the program.
It makes it so much easier to see what's wrong and help.
Stefan Vendin
Old 01-15-2008, 02:33 PM
I second this suggestion and add; copy and paste the actual program don't just retype a segment. Typos can occur during retyping which just confuses the issue.
Old 01-16-2008, 06:55 AM
Stu_M3 is on a distinguished road
It also makes sense to specify the machine the control and also put a few punctuation marks in sentences. Some of the posts are a joke we ought to start a new forum with all the worst examples posted. You know the kind " Need help how to mill a circle ? " .
Stu
Old 01-16-2008, 10:03 AM
Andre' B is on a distinguished road
Use of the code tags helps a lot, sets off the program and preserves the formatting.
Just push this button and put your text between the start and end tags which are inside the two sets of square brackets.
Code:
N1M1(3/8 END MILL)
T#101M6
M1
G0G90G#103X0.000Y0.000
S3565M3
G43Z1.000H#101M8
(FEED RATE)
#9=21.39
G65P1001Z-0.750R0.100D#101A#100F#9
G65P1002Z-0.625R0.100D#101A#100F#9
G0Z1.000M9
G91G28Z0M5
Old 01-16-2008, 10:15 AM
Thank you; that is one of today's 'new things learnt'.
Old 01-16-2008, 12:42 PM
Stu
Well,maybe one or two come here to learn.
Stefan Vendin
Old 01-17-2008, 12:37 AM
psychomill is on a distinguished road
Unfortunately, most of "them" won't actually read this thread to take the advice.....
It's just a part..... cutter still goes round and round....
Old 01-17-2008, 12:58 AM
.... Not very optimistic. Guess my glass was half empty today...
Old 01-17-2008, 01:30 AM
You're probably right.Most people won't read this thread.
Maybe a sticky would be a good idea?!
My glass is full so fill up. Cheers!
Stefan Vendin
Old 01-31-2008, 08:14 PM
g-codeguy is on a distinguished road
Code:
N1M1(3/8 END MILL)
T#101M6
M1
S3565M3
G43Z1.000H#101M8
(FEED RATE)
#9=21.39
G0Z1.000M9
G91G28Z0M5
Andre' B, I am pretty much a computer illiterate in many ways. What are "code tags"? Are you saying to do this?
part program
And this will show the program in the thread exactly as it was written for the machine?
I also like to learn new things.
Thanks.
  #11   Ban this user!
Old 01-31-2008, 08:53 PM
dapoling is on a distinguished road
Here is a little tool that will help in trouble shooting G and M code, only draw back it does not recognize macros.
Discriminator CNC Editor It is $10 and works well and is a good tool for teaching G and M code along with manual editing and trouble shooting.
You are able to step through each line of code and visually see the output.
My Response to "It's Close Enough", "Is Your Tool Box and The Door Close Enough?"
  #12   Ban this user!
Old 02-01-2008, 08:55 AM
Code:
Put your code between the tags.
Edit:
Regular text in a reply the "extra" blank spaces get removed.
* I put 9 spaces before the * char.
Code:
Inside the code tags the spaces are not removed.
Also a mono spaced font is used inside the tags so stuff lines up vertically.
Name:	Code Tags.jpg‎
Sample 4th axis Program please.... bullseye Mach Mill 7 06-02-2010 04:42 PM
Need IEI-ISO sample program for Mazatrol 640 T turkaygeyik Mazak, Mitsubishi, Mazatrol 0 05-29-2007 09:03 AM
Sample Nisshinbo g-code program ehab General CNC (Mill and Lathe) Control Software (NC) 1 09-16-2006 05:20 PM
mori with t6- b controller sample program needed anyfish Fanuc 0 02-03-2006 05:58 AM
I need sample G code program bunalmis G-Code Programing 1 08-24-2004 03:50 AM
