| G-Code Programing Discuss G-code programing and problems here! |
| Hi Folks! I just got my first professional job as an Adjunct CNC Instructor, and Im in need of some refreshers. Im trying to remember some ways to program bolt hole circles using g-code. Im working with fanuc controls - and want to use a g81 canned cycle... but am rusty on how to set up the block. Any suggestions? Thanks! (p.s. the more suggestions the better!) |
| Here is a custom macro that machines a bolt hole pattern. O0008 (Main program) N005 G54 G90 S800 M03 T02 (Select coordinate system, absolute mode, start spindle, get next tool ready) N010 G00 X3.0 Y2.5 (Rapid to center of bolt hole pattern) N015 G43 H01 Z.1 (Instate tool length compensation, rapid up to workpiece) N020 G65 P1008 X3.0 Y2.5 Z0 R1.75 D0.75 A45.0 H8.0 C81. F5.0 (Machine entire bolt hole pattern with drilling cycle) N025. . . . . . X - Position in X for center of bolt hole pattern Y - Position in Y for center of bolt hole pattern Z - Surface in Z into which holes are machined R - Radius of bolt hole pattern D - Depth of holes A - Starting angle (0 is three o'clock position, plus is ccw) H - Number of holes C - Cycle type (81 is for drilling, 84 for tapping, etc.) F - Feedrate for machining Here's the actual custom macro (program O1008). O1008 (Custom macro to machine bolt hole circle) #101=1 (Initialize counter) #102=#1 (Initialize current angle to A) #103=360 / #11 (Constant for incremental angular distance between holes) #104=#26 + 0.1 (Constant for rapid approach plane) #105=#26 - #7 (Constant for Z bottom position of hole) N1 IF [#101 GT #11] GOTO 99 (Test if loop is finished) #110=#24 + COS[#102] * #18 (Calculate X position for current hole based on current angle) #111=#25 + SIN[#102] * #18 (Calculate Y position for current hole based on current angle) G#3 X#110 Y#111 R#104 Z#105 F#9 (Machine current hole) G80 (Cancel cycle) #101=#101 + 1 (Step counter) #102=#102 + #103 (Step current angle) GOTO 1 (Go back to test at loop beginning) N99 M99 (End of custom macro)
__________________ Stefan Vendin |
| I'd recommend you have a look at some basic training resources. It sounds like you're likely to have some more CNC questions. ![]() CNC Concepts has great information. http://www.cncci.com
__________________ Software For Metalworking http://closetolerancesoftware.com |
| it's going to be a little different for each control type T1M6 ;TOOL CALL S1000M3 ;CW SPINDLE 1000RPM N100G81X1.Y2.C.1D-.75F6. ;G81 CANNED CYCLE + FIRST HOLE ,POSITION ,CLEARANCE PLANE AND DEPTH N200X-1.Y2. ;SECOND HOLE N300X-1.Y-2. ;THIRD HOLE N400X1.Y-2. ;FORTH HOLE N500G80 ;CANCEL CANNED CYCLE (G81) DRILLING CYCLE (DRILLS FROM CLEARANCE PLANE TO DEPTH IN FEED MODE THEN RETRACTS TO CLEARANCE PLANE IN RAPID MODE) (X,Y) POSITION OF HOLE TO BE DRILL (C) CLEARANCE PLANE (D) DEPTH (IN ABSOLUTE POSITIONING THIS WOULD BE FROM PART ZERO ,INCREMENTAL FROM CLEARANCE PLANE ) (F) FEED RATE (IPM) (CHIP LOAD = FEED RATE / RPM) / 2 PER TOOTH (X,Y) OTHER HOLE POSITIONS (G80) CANCEL CANNED CYCLE HOPE THIS HELPS KEVIN |
| Not to be rude, but this probably will be..... How do you get a job (or go looking for one) as a "cnc instructor" and not understand something so generic as a G81 cycle?... even if its for "bolt circle"... What exactly is it that the course you're instructing consist of? Curious........??
__________________ It's just a part..... cutter still goes round and round.... |
| And on a machine the does not do polar. Code: G0X0.0 Y0.0 Z0.1 G81 R0.1 Z -0.1 F3 L0 X[2*COS[0]] Y[2*SIN[0]] X[2*COS[60]] Y[2*SIN[60]] X[2*COS[120]] Y[2*SIN[120]] X[2*COS[180]] Y[2*SIN[180]] X[2*COS[240]] Y[2*SIN[240]] X[2*COS[300]] Y[2*SIN[300]] G80 G0 X0.0 Y0.0 Z0.1 (OR WITH A LOOP) G0X0.0 Y0.0 Z0.1 G81 R0.1 Z -0.1 F3 L0 #100=45(START ANGLE) #101=3(RADIUS) #102=15(ANGLE INCREMENT) (* ------------- *) #103=#100+360 WHILE[#100LT#103]DO1 X[#101*COS[#100]] Y[#101*SIN[#100]] #100=#100+#102 END1 G80 G0 X0.0 Y0.0 Z0.1 |
#10
Just for future reference, The green button is usaully "ON" and the big red one is the "E STOP" (Probobly need that one the most) Bluesman |
#11
he may have put the horse in front of the cart but at least he's trying ,someone has to you can't knock someone for trying |
#12
| Dude, He is the instructor he should be beyound trying Bluesman |
| Partial Bolt Hole Circle | barks | Okuma | 8 | 11-25-2009 02:41 AM |
| macro bolt circle | jdsmith0524 | G-Code Programing | 3 | 05-16-2007 07:09 PM |
| I Need Help G Coding A Bolt Circle | capitalv | G-Code Programing | 14 | 02-25-2007 03:41 PM |
| bolt hole circle | sanddrag | Employment Opportunity | 5 | 01-23-2007 06:52 AM |
