Old 12-23-2007, 06:19 PM
Fendertok is on a distinguished road
How to repeat a Mazak EIA/ISO prog??
Is there a way to repeat a program without making a sub prog?
Im using a barpuller and i want to repeat the a program 30 times, i have tried M98 L30 but it just repeats the program forever. This is what the end looks like:
G01 Z2.
M98 L3
G00 X200. Z200.
M5
M30
Old 12-23-2007, 08:03 PM
theemudracer is on a distinguished road
At the end of your prg. you have to setup a counter like this. There are many differnt ways to do this, this is just one example.
#529=30.(NUMBER OF PARTS TO BE MACHINED); You can put this at the front of the program so it is easier to change.
#530=1.;
#531=[#531+#530];
IF[#531EQ#529]GOTO900;
M99;
N900
#529=#0;
#530=#0;
#531=#0;
#3006=100(COUNT UP);
M30;
We also use a dedicated loop program like this
G28U0;
M98P304545;
M30;
It will run program #4545 30 times and then hit the M30 and reset.
Old 12-23-2007, 08:08 PM
Chartal is on a distinguished road
Hi.
You can try M97 to call local Sub-Program.
O#### (Main Program)
M97 P1000 L3 (Call Local Sub-Program at line N1000 and repeat 3 times)
M30
N1000 (Local Sub-Program)
M99 (End of Sub-Program and return to Main-Program)
Old 12-24-2007, 04:27 AM
I forgot to say that its a T32-3 control with eia/iso option.
Do you think it will work with that?
What control do you use?
Old 12-24-2007, 09:28 AM
ChattaMan is on a distinguished road
OR
O0001
#500=1
WHILE[#500LE30]DO1
...your prog
blah, blah
...blah
#500=#500+1
END1
M30
Old 12-26-2007, 10:08 AM
psychomill is on a distinguished road
M97 won't work either... that's a Haas code.
You'll probably need a counter like above examples. You could also try this:
M98H????L30 (where H is the "N" number or sequence number to start from).
Using the M98 like this is similar to a Haas M97.
It's just a part..... cutter still goes round and round....
Old 12-27-2007, 09:38 AM
Tried like this but only got illegal format alarm.
Why wont this work and on a Mazak T32?
This is my current testprog:
O5002 ( TEST 12-26-2007 )
( MAZAK T32-3 )
( TOOL:10 CLAW )
( OPERATION: BAR PULLER )
N10 G18 G21 G53 G98
M302
G00 X200. Z200.
M202( SVARVNING )
T1010
G97 S0 M04
G00 X0. Z2.5
Z-17.5
G01 Z-25.0 F2000.00
M5
M8 (KLAW GRIP)
G04 X2000
M6 (CHUCK OPEN)
G04 X500
Z-5.0 F2000.00
M7 (CHUCK CLOSE)
M9 (KLAW OPEN)
G04 X1500
G01 Z2.5 F2000.00
G00 X200. Z200.
M5
#529=2.(REP)
#530=1.
#531=[#531+#530]
IF[#531EQ#529]GOTO30
M99
N30
#529=#0
#530=#0
#531=#0
#3006=100(COUNT UP)
M30
Old 12-27-2007, 07:46 PM
What control does it have?
Did it alarm out as soon as you hit Cycle start or a couple of lines before the counter variables?
Have you used variables before in this control??
Old 12-28-2007, 03:40 AM
Its a Mazatrol T32-3 system with EIA/ISO option, i have never used variables in iso and im not sure how the T32 handles the variables, cant find anything about it in the books. I will get a alarm at the first line of variables, " illegal format " The program works fine up to the variables. Is variables the only way to make it count?
Old 12-28-2007, 05:35 AM
I dont know anything about the Mazatrol control. You might not have Macros enabled on that machine. You might need to go to the Mazatrol forum.
  #11   Ban this user!
Old 12-28-2007, 09:46 AM
Try this to test macro option:
#500=10.
And see if it puts a "10" into #500 or gives you a format error. A T32 with macro options should handle variables like any other machine.
Anyone familier with (KipwareM cnc prog) Holmes_ca General CAM Discussion 5 05-01-2011 08:55 PM
Fanuc Ot PMC prog problems F.Sharifi Fanuc 4 09-07-2010 10:25 AM
Alarm 913 prog: Fanuc 6T mrvirtue Machine Problems, Solutions , Wireless DNC, serial port 1 10-30-2006 04:14 PM
Need Prog. Manual For Boss 5! MrHorsepower Bridgeport and Hardinge Mills 6 07-23-2005 07:14 PM
