Old 12-15-2007, 10:37 AM
adamant is on a distinguished road
Fanuc T6 Control
Howdy folks,
I got a job yesterday making a part with an old Okuma turning center with a T6 control.
Two things in G-code I could not get it to do.
G75. CUT OFF
I'm use to a two line G75
G75R50
G75x.4P200F.002
I tried using a one line format and it did not like that either so I ended up G1ing it.
What is the one line G75 format for the older Fanucs?
I also tried doing a stock up with a M21 for opening the Collet............
Found a link here for that
http://www.cnczone.com/vb...d.php?p=781290
Any advice on G-code for this machine will help.
Thanks,
Patrick
Old 12-17-2007, 04:32 PM
g-codeguy is on a distinguished road
G75X...Z...I...K...F...D... No decimal point in the "D". Two block G75 uses a decimal point with the R-value.
Hardinge uses M21 to open collet, but that doesn't mean that Okuma does. Call Okuma if you don't have a manual for your machine. Or maybe someone with an older Okuma will respond. Did you ask about it on the Okuma Forum?
Old 12-18-2007, 03:50 AM
eject_21 is on a distinguished road
try I instead of P.
Old 12-18-2007, 10:46 AM
Originally Posted by eject_21 View Post
try I instead of P.
Yup, that was it.
I do have a manual, with the formats in it, but particular page was ripped out. I found the page stuffed in the back of a cabinet with a bunck of oil, nuts, bolks ect.............
Took me three tries yesterday till I got one that worked. I was cutting A-286 so I was glad I did.
g-codeguy G75X...Z...I...K...F...D...
Thanks g-codeguy
never did figure out what opens the collet........made 40 parts manual stockinging up.
M5
GOX.6Z.030
MOO(FOOT PEDAL COLLET OPEN- PULL STOCK- FOOT PEDAL CLOSE COLLET)
MP8P1
Thanks for your help,
I'll try the Okuma page.
Patrick
Old 12-18-2007, 07:50 PM
Originally Posted by adamant View Post
Yup, that was it.
Thanks g-codeguy
M5
GOX.6Z.030
MP8P1
Patrick
Apparently your G75 call is different from anything I have ever seen. Not saying I've seen everything. Never have worked on a 6T. We have one Okuma, but it has one of their own controls on it. Glad you were able to get it working.
Old 12-19-2007, 11:09 AM
g-codeguy,
Your format was correct.
I was trying to use p, instead of I, because p is used in the two line format.
Thanks again for your help.
Help with Fanuc 6m control inaman Fanuc 5 02-03-2012 12:49 PM
fanuc 6m control earl General Metalwork Discussion 2 02-25-2007 01:48 PM
FANUC OT control need dnc help mike10 Fanuc 5 10-17-2006 03:27 PM
Fanuc 18T control m_ghaff2000 Fanuc 1 09-26-2006 07:05 AM
fanuc 0tf control gcrandall Fanuc 8 09-03-2006 01:55 AM
