Old 12-03-2007, 05:35 AM
maximusek is on a distinguished road
T - parameter in Siemens contr.
Hi!!
;0100
(T1 - 1.5mm Ball)
S1000M3
G0G90X.203Y-6.708T2
M22
G0A337.G43Z.55H1
M21
Part of the subprogram above contains two parameters T and H, H is a tool offset amount specified to be added to or subtracted from the Z-axis position (G43). I don't know what is T2...tool is stored under #1, I call it in the main program by T1M6. Machine Matsuura ES-1000V, controller Yaskawa Siemens G-tech 840Dl...Thank You for any clue
Old 12-03-2007, 01:49 PM
Sump Cleaner's Avatar
Sump Cleaner is on a distinguished road
Maximusek,
When you call a T value by itself (without an M6) it should move that tool number to the change position and bring the tool pocket to the change arm. This just decreases the time it takes to do a tool change by having the magazine rotate during the maching cycle.
JK
Old 12-06-2007, 11:29 AM
Originally Posted by Sump Cleaner View Post
Maximusek,
JK
Thx Sump Cleaner, that baby is new 4 me so I'm quite sure I'll write many posts, the good thing is my first program for her works, thx again
Old 12-06-2007, 12:24 PM
No Problem,
I have a Mat here with a 840 DI control. It is a H Plus 405 but I'm sure the controls are very similar so fire your questions away....
JK
parameter davek Fanuc 6 11-08-2007 07:45 AM
H parameter in G84 IMEC General CAM Discussion 1 10-31-2007 06:41 PM
dnc parameter help shepherd Machine Problems, Solutions , Wireless DNC, serial port 1 06-27-2007 12:28 AM
parameter 64 swartling Haas Mills 0 02-20-2007 04:57 PM
