| G-Code Programing Discuss G-code programing and problems here! |
I'm not sure why this code is skipping depth passes after the stops at the beginning. I'm trying to run the same contour code over and over and incrementing the depth by 0.02" each pass. For whatever reason, it goes from -0.02, to 0.06 to 0.10, to 0.14. It's skipping 4, 8, 12 etc. Did I do something wrong or is this a limitation of the Mach3 demo? (File created using FlashCut CNC DXF Import) (Import File: Dekley Bellcrank.dxf) (Import Date: 11/20/2007) (3/8" hole) G00 Z0.20000 G00 X1.5525 Y0.3775 M0 (1/4" hole) G00 Z0.20000 G00 X1.0775 Y0.3775 M0 (1/4" hole) G00 Z0.20000 G00 X0.7575 Y0.3775 M0 (1/4" hole) G00 Z0.20000 G00 X0.4375 Y0.3775 M0 (1/4" hole) G00 Z0.20000 G00 X0.1175 Y0.3775 M0 (insert 1/8" endmill) M0 G00 Z0.20000 G00 X0.00000 Y0.06300 G01 Z-0.02000 F1.00 M98 P1 G01 Z-0.04000 F1.00 M98 P1 G01 Z-0.06000 F1.00 M98 P1 G01 Z-0.08000 F1.00 M98 P1 G01 Z-0.10000 F1.00 M98 P1 G01 Z-0.12000 F1.00 M98 P1 G01 Z-0.14000 F1.00 M98 P1 G01 Z-0.16000 F1.00 M98 P1 G01 Z-0.18000 F1.00 M98 P1 G01 Z-0.20000 F1.00 M98 P1 G01 Z-0.22000 F1.00 M98 P1 G01 Z-0.24000 F1.00 M98 P1 G01 Z-0.26000 F1.00 M98 P1 G01 Z-0.28000 F1.00 M98 P1 G01 Z-0.30000 F1.00 M98 P1 G01 Z-0.32000 F1.00 M98 P1 G01 Z-0.34000 F1.00 M98 P1 G01 Z-0.36000 F1.00 M98 P1 G01 Z-0.38000 F1.00 M98 P1 G00 Z1 G00 X0.00000 Y0.00000 M30 O1 G03 X0.06300 Y0.00000 I0.06300 J-0.00000 F18.00 G01 X1.67800 Y0.00000 G03 X1.67800 Y0.75600 I0.00000 J0.37800 G01 X0.06300 Y0.75600 G03 X0.00000 Y0.69300 I0.00000 J-0.06300 G01 X0.00000 Y0.06300 M99
__________________ Gary Shepherd www.16tracks.com |
| Also, my Z-axis never seems to go deep enough with I run the program. But I've checked it while not running a program and the distance is true to what the DRO reads.
| I suppose it is difficult to say why, because it could be a result of the way the gcode is being interpreted. Special syntax rules may be required because the controller software may not have logic to correctly return to the main program using your syntax. For example, to alter the syntax, try putting the subroutine call on a seperate line beneath each Z move. You might also put the Z movement into the subroutine: O1 G91 G01 Z-.02 F1. G90 etc. This would then permit you to write the main program with a single line calling for repeats, something like: G00 Z0.20000 G00 X0.00000 Y0.06300 M98 P1 L19
The control read more than just one block.It stays ahead and sometimes you need blind blocks to "force" it to read everything. |
Is your Z workzero set right?Tool lenght?Tool length comp. set to zero? Last edited by Mitsui Seiki; 11-21-2007 at 12:25 PM. Reason: Add comment. |
#12
| Just place the subprogram call on a separate line. I always place subprograms or subroutines calls on a separate line. So: G00 X0.00000 Y0.06300 G01 Z-0.02000 F1.00 M98 P1 G01 Z-0.04000 F1.00 M98 P1 Would become: G00 X0.00000 Y0.06300 G01 Z-0.02000 F1.00 M98 P1 G01 Z-0.04000 F1.00 M98 P1
__________________ Safety - Quality - Production. |
| Mazak Block Skips | ajl6549 | Mazak, Mitsubishi, Mazatrol | 2 | 03-05-2007 11:37 AM |
| torque skips | scappini | Fanuc | 0 | 02-02-2007 04:07 AM |
| PRoblem seeing dxf lines | Ed_R | SheetCam | 4 | 03-25-2006 03:32 PM |
| Anyone got any basic examples of a program using a subroutine/program? | Darc | CamSoft Products | 11 | 10-08-2005 11:45 PM |
| Can't see lines | Mr.Chips | TurboCAD/CAM | 4 | 04-03-2005 10:29 AM |
