Old 11-18-2007, 02:09 PM
DroopyPawn is on a distinguished road
Manually Change Endmill
What code do I add to my program so that I can manually change endmills? I'll need to pause the program, change the tool, rezero the z-axis and resume the program from the paused position.
Gary Shepherd
www.16tracks.com
Old 11-18-2007, 07:41 PM
Mitsui Seiki's Avatar
Mitsui Seiki is on a distinguished road
Add a M0 before the tool change.Switch to "Jog",change the tool,rezero and go back to Auto mode and start from where you paused.
Old 11-18-2007, 11:51 PM
That worked out well, thanks.
Now another question...
My code was generated by a downloaded demo of FlashCutCNC. The code is good but it's about 1000 lines long. My demo version of Mach3 only allows 500 lines of code.
Here's the code to do the outside contour of my part...
N10 G00 Z0.20000
N20 G00 X0.06200 Y0.00000
N30 G01 Z-0.02000 F12.00
N40 G01 X2.06200 Y0.00000
N50 G03 X2.12400 Y0.06200 I0.00000 J0.06200
N60 G01 X2.12400 Y0.81200
N70 G03 X2.06200 Y0.87400 I-0.06200 J0.00000
N80 G01 X1.77334 Y0.87400
N90 G03 X1.76165 Y0.87290 I-0.00004 J-0.06200
N100 G03 X1.75000 Y0.87400 I-0.01165 J-0.06090
N110 G01 X1.43700 Y0.87400
N120 G03 X1.37500 Y0.81200 I0.00000 J-0.06200
N130 G01 X1.37500 Y0.62404
N140 G01 X1.31196 Y0.62400
N150 G03 X1.25000 Y0.56200 I0.00004 J-0.06200
N160 G01 X1.25000 Y0.24904
N170 G01 X1.24900 Y0.24904
N180 G01 X1.24900 Y0.56200
N190 G03 X1.18700 Y0.62400 I-0.06200 J0.00000
N200 G01 X1.06200 Y0.62400
N210 G03 X1.00000 Y0.56200 I0.00000 J-0.06200
N220 G01 X1.00000 Y0.24904
N230 G01 X0.99900 Y0.24904
N240 G01 X0.99900 Y0.56200
N250 G03 X0.93700 Y0.62400 I-0.06200 J0.00000
N260 G01 X0.81200 Y0.62400
N270 G03 X0.75000 Y0.56200 I0.00000 J-0.06200
N280 G01 X0.75000 Y0.24904
N290 G01 X0.74900 Y0.24904
N300 G01 X0.74900 Y0.56200
N310 G03 X0.68700 Y0.62400 I-0.06200 J0.00000
N320 G01 X0.56200 Y0.62400
N330 G03 X0.50000 Y0.56200 I0.00000 J-0.06200
N340 G01 X0.50000 Y0.24904
N350 G01 X0.49900 Y0.24904
N360 G01 X0.49900 Y0.56200
N370 G03 X0.43700 Y0.62400 I-0.06200 J0.00000
N380 G01 X0.31200 Y0.62400
N390 G03 X0.25000 Y0.56200 I0.00000 J-0.06200
N400 G01 X0.25000 Y0.24954
N410 G02 X0.24900 Y0.24954 I-0.00050 J0.00000
N420 G01 X0.24900 Y0.56200
N430 G03 X0.18700 Y0.62400 I-0.06200 J0.00000
N440 G01 X0.06200 Y0.62400
N450 G03 X0.00000 Y0.56200 I-0.00000 J-0.06200
N460 G01 X0.00000 Y0.06200
N470 G03 X0.06200 Y0.00000 I0.06200 J-0.00000
I know that I can make lines 40 through 470 a subroutine and just call it over and over (after z changes) but I'm not sure exactly how that works. That would shorten my code A LOT. Not sure if Mach3 would still call it more than the 500 lines allowed in the demo but it will work until I have some extra money to register my copy of the program.
So how can I do the subroutine thing correctly?
Gary Shepherd
www.16tracks.com
Old 11-19-2007, 02:08 PM
Do it like this:
"Main prog with Z change."(0001)
(Call sub)M98 P0002( Line 40 through 470)
Z change
(Call sub) M98 P0002
Z change
M30
Old 11-19-2007, 02:55 PM
Yep. I got it working fine. My program went from over 1000 lines to about 70.
Thanks, gs
Gary Shepherd
www.16tracks.com
Old 11-19-2007, 05:35 PM
drewmeister is on a distinguished road
another easy way to shorten you program even more is make the z move incremental then swith back to absolute. just make sure the tool doesn't move up at the end of the sub.
Old 11-19-2007, 05:56 PM
Well here's what I did. How would I make it incremental and shorter?
(Drilling Shaft Hole with 3/8" drill)
N1 G00 Z2
N2 G00 X1.749 Y0.437
N3 G01 Z0.1 F25
N4 G01 Z-0.3 F15
N5 G00 Z1.5 F25
N6 M0 (change to 1/8" endmill)
G00 Z0.20000
G01 X0.06200 Y0.00000 F150.00
G01 Z-0.02000 M98 P1
G01 Z-0.04000 M98 P1
G01 Z-0.06000 M98 P1
G01 Z-0.08000 M98 P1
G01 Z-0.10000 M98 P1
G01 Z-0.12000 M98 P1
G01 Z-0.14000 M98 P1
G01 Z-0.16000 M98 P1
G01 Z-0.18000 M98 P1
G01 Z-0.20000 M98 P1
G01 Z-0.22000 M98 P1
G01 Z-0.24000 M98 P1
G01 Z-0.26000 M98 P1
G01 Z-0.28000 M98 P1
G01 Z-0.30000 M98 P1
M30
O1 (Subroutine - Contour the part)
M99
Gary Shepherd
www.16tracks.com
Old 11-20-2007, 12:47 AM
This is a little shorter.
You use G91 G1 Z -0.02 at the end of the sub prog (O01)
And you need to have a second sub prog (O02)without the Z drop at the end..
That takes up more space in your machine though.
Unless you use block skip on the Z drop and turn it on when it does it's last run.That way you don't need the second sub prog.
Code:
N1 G00 Z2
N3 G01 Z0.1 F25
N4 G01 Z-0.3 F15
N5 G00 Z1.5 F25
G00 Z0.20000
M98 P1
M98 P1
M98 P1
M98 P1
M98 P1
M98 P1
M98 P1
M98 P1
M98 P1
M98 P1
M98 P1
M98 P1
M98 P1
M98 P1
M98 P2
M30
G91G1Z-0.02
G90
M99
O2 (Subroutine - Contour the part)
M99
Old 11-20-2007, 12:52 AM
Ok. What happens when I want to go cut something else? Say for example, I want to cut the same part an inch away from the first part. Do I just set z to 1", move my x and y, and start over or does the G91 cause some kind of problem? Or will a G90 set things back to normal?
Thanks for taking the time to explain all this stuff.
Gary Shepherd
www.16tracks.com
Old 11-20-2007, 01:04 AM
Do that.And G90 will set it all back to normal.
I changed it a bit.I put the G90 at the end of the sub prog.
How to change Tool change position(About MAZATROL T1 control) liushuixingyun Mazak, Mitsubishi, Mazatrol 5 07-07-2007 02:58 PM
Endmill selection sdantonio Wood Working Tooling 1 04-07-2007 10:44 PM
Please help me identify AMS endmill johnbirch General Metalwork Discussion 0 04-07-2007 03:22 PM
How do you move an axis manually ? Eurisko DIY-CNC Router Table Machines 6 04-06-2007 09:00 PM
Manually starting spindle with edge finder diemaker76 Fadal 21 04-13-2006 06:13 PM
