Old 11-11-2007, 10:11 PM
HakBot is on a distinguished road
Reverse direction?
Hello,
I am currently using ACE converter to convert my autocad files to g-code. I am milling 1/4 ABS plastic and I noticed that my milled parts come out very rough on the part side but very smooth on the leftover ABS material. I believe that this is due to the rotation direction of the bit and the actual direction that my mill travels.
What I would like to do is reverse my cut direction but the only options I see in ACE is the ability to reverse the arc direction from clockwise to counterclockwise. How can I reverse the path my mill takes so that I get the smooth edges I am looking for?
Phil
Old 11-12-2007, 10:25 AM
ger21's Avatar
Try drawing the lines in the direction you want them cut, and don't let ACE optimize the code.
Old 11-19-2007, 04:30 PM
Is that the only way? I have my CAD drawings already done and Id hate to have to re-do them. Is there another g-code converter that will do this? Seems to me that this would be fairly common. Thanks.
Reverse frankg521 Mach Mill 3 08-05-2007 09:08 PM
Reverse? UKRobotics General Metal Working Machines 3 09-11-2006 06:20 PM
Reverse CNC adwsystems General CAM Discussion 4 05-16-2006 07:05 AM
Reverse axis direction? saturnnights Machines running Mach Software 5 03-28-2006 08:40 PM
my DIY CNC progress in reverse slp_prlzys DIY-CNC Router Table Machines 1 11-14-2004 11:44 PM
