| G-Code Programing Discuss G-code programing and problems here! |
| need code to mill a hole 1.22" in dia., in .750 Hot roll plate, located X6.375Y-3.5 using a .50 carbide end mill S2200F4.0. I will start by drilling a 1" hole. Thank You in advance for any help Last edited by krfrea; 11-20-2007 at 09:27 AM. |
| Here is a link to a free circle millimg program . http://www.kentechinc.com/tip7.html
__________________ Tim |
| Thanks for your help. I have used the circle milling program mentioned above and wrote the following main and sub program. Any comments would be appreciated. % O0001 (1" INGERSOL DRILL) M6T9 G00G20G40G49G80G90G98G54 G43X6.375Y-3.50Z0.2H9M3S1800 M8 G83Z-.90R.1Q.36F3.8 G00G91G28Z0.M19 G80M9 G00G91G28Z0.M19 (MILL 1.22" HOLE W/1/2" END MILL) M6T5 G54 G90S2200M03 G00X6.375Y-3.50Z0.2H9M3S1800 M8 G01G90Z-.250F4.0 M98P0002 G01G90Z-.500F4.0 M98P0002 G01G90Z-.800F4.0M09 M98P0002 G00Z.2 G80M9 G00G94G28G53X-12.Y0.Z0.M5 M30 % % O0002(CUTTING PROGRAM 1.22 DIA) G02G91G42X.36Y0R.18D15 G02I-.36 G02X-.36Y0R.18 G40M99 % |
| I'm not sure the reasons you have the code as you do. But it should work with some fixs. This code reverts the RPM back to 1800 and calls the T9 length offset for T5. G90S2200M03 G00X6.375Y-3.50Z0.2H9M3S1800 needs to be changed to: G90S2200M03 G00X6.375Y-3.50Z0.2H5 (assuming the G43 was not canceled) And I would also add to: G01G90Z-.800F4.0M09 M98P0002 I would add a finish spring pass: G01G90Z-.800F4.0M09 M98P0002 F19. M98P0002 Also I would change the code from G42 G2 to G41 G3: % O0002(CUTTING PROGRAM 1.22 DIA) G03G91G41X.36Y0R.18D15 G03I-.36 G03X-.36Y0R.18 G40M99 % Since convental cutting tends to suck the tool into the work and cut bigger. (Now only if the material is harder on the outside than on the inside you would want your first cut G42 G2 and your last cut G42 G2 with the middle cut G41 G3 and the finish spring cut G41 G3. IMO) Test your code out without any material in the machine and see if it looks and moves the way you expect. (Dry run.) Also is there a reason that the SFPM for the drill is 471 and the mill is 287? Usually the drilling SFPM is less than the milling SFPM.
__________________ Safety - Quality - Production. Last edited by Paul_S; 11-22-2007 at 03:43 AM. |
| This would be my 2 cents % O0001 (1" INGERSOL DRILL) G00G20G40G49G80G90G98G54 T5M6 G0G90G54X6.375Y-3.50M3S1800 G43Z.2H5M8 G83Z-.90R.1Q.36F3.8 G80 M9 G00G91G28Z0.M19 M1 (MILL 1.22" HOLE W/1/2" END MILL) T9M6 G00G90G54X6.375Y-3.50M3S2200 G43Z.2H9M8 G0Z0 M98P0002L4 G0Z.2 M9 G00G94G28G53X-12.Y0.Z0.M5 M30 O0002(CUTTING PROGRAM 1.22 DIA) G0G91Z-.2 G1G41X.18Y-.18F5.D15 G3X.18Y.18J.18 X-.72I-.36 X.72I.36 X-.72I-.36 X.72I.36 X-.18Y.18I-.18 G1G40X-.18Y-.18 G90 M99 %
__________________ If you can ENVISION it I can make it |
| I DONT KNOW WHAT TYPE OF CONTROL THAT YOU ARE USING BUT ALL G CODE CONTROLS I HAVE G90 AND ALSO G91 ARE MODEL I HAVE AN OLD FANUC 10M ON A MORI SEKI THAT I HAVE TO G91 G28Z0 BECAUSE IT DOES NOT HAVE ABSOULTE ENCODER SEEMS LIKE A LOT OF CODE TO MILL A CIRCLE.BUT IF IT WORKS FOR YOU THAT WAY GREAT!!! WE HAVE SEVEN MAZAKS SO I GUESS IAM SPOILED WITH THE SHORT CODE.GOOD LUCK |
| Thank you guys for all your help. I managed to get the holes done and they came out perfect. When I get time I plan on using the changes and ideas from you and writing a program so when I need a hole all I have to do is enter the R etc. thanks again, Ken |
| error code on an okuma mill | delbert | General CNC (Mill and Lathe) Control Software (NC) | 2 | 08-16-2010 05:26 AM |
| haas vf-4 mill not reading code | WhiteZee | Haas Mills | 10 | 06-09-2007 02:53 PM |
| Alignment of mill to hole | mugabe | General Metalwork Discussion | 2 | 02-22-2007 04:38 PM |
| Postprocessor code always drilling same hole twice | Maurice Proulx | SprutCAM | 2 | 12-07-2006 09:03 PM |
| Knee Mill Hole Pattern | Zumba | Mechanical Calculations/Engineering Design | 2 | 10-11-2006 12:47 AM |
