| G-Code Programing Discuss G-code programing and problems here! |
I can understand the use of "Tool length compensation" G43, G44,G49. Can someone explain why and when "tool offset" needs to be programmed. G45 Tool offset increase G46 Tool offset decrease G47....... G48........ Is this some cain of wear offset??????? Any explanation will be appreciated. Jorge |
| I don't think I've ever used them in the 28 years I've been programming Fanuc or Yasnac controls... however: They're usually used instead of G41/G42 to increase or decrease an X or Y move by the value stored in the D offset. I suppose they could be used if you were milling rectangles with 90 degree corner radii all day long, but I'd still use G41/G42. |
| I have used these codes when programming for right angle heads. It was some time ago and my memory is a little hazy, but I used G47 in conjunction with G18 to use offsets that enabled canned drill cycles to execute correctly. G48 was used to clear the offset IIRC. |
| How long does 'D' last and tool offset for G3? | Witsenburg | G-Code Programing | 1 | 06-03-2007 03:47 PM |
| Tool Offset Icons | dafowfidy | Mach Software (ArtSoft software) | 0 | 03-21-2007 11:06 PM |
| Trouble with tool offset VF-2 | LorenzoNH | Haas Mills | 1 | 01-30-2007 08:12 PM |
| Tool offset ... | patrickb | Fanuc | 13 | 08-21-2006 10:53 AM |
| Tool Offset | 3rdcoast | Mach Software (ArtSoft software) | 1 | 05-19-2006 01:08 PM |
