Old 10-16-2007, 07:15 PM
bdyenter is on a distinguished road
Smile 3/4"-14 npt exterior thread
Please help.....
Looking for a program to do a 3/4"-14 npt exterior thread on a lathe. I cannot figure out from the machinery's handbook how to figure out the "x" number in the 2nd G76 line......
Would someone explain how to come up the the "x" in the G76 cycle for both inside and outside threads. I can figure out the tapers to rough turn or bore the stock to. I can also figure out the "r" value in the G76 line, but not the x......
PLEASE HELP!!!!
THANKS!
Old 10-16-2007, 08:47 PM
Karl_T's Avatar
Karl_T is on a distinguished road
Here is a blurb on G76 threading. If you are doing an NPT thread you will have to use the R(i) value to taper the thread. The value is an interger number with 1 being equal to .0001" and is the difference in radius from Z start to Z finish. Hope this helps you out.
G76 P(m)(r)(a) Q(min) R(fin)
G76 X(Øfin) Z(len) R(i) P(k) Q(1st) F(L)
WHERE
m = SPRING CUTS (01)
r = CHAMFER AMOUNT(00)
a = TOOL ANGLE (80 60 55 30 29 0)
min = MINIMUM DEPTH OF CUT
fin = FINISHING ALLOWANCE
Øfin = ROOT DIAMETER
len = LENGTH OF THREAD
i = THREAD RADIUS DIFFERENCE
k = THREAD HEIGHT (RADIUS)
1st = 1ST CUT DEPTH
L = THREAD LEAD
Old 10-16-2007, 09:18 PM
valmet58 is on a distinguished road
which program are you using to drive your lathe..Turbocnc mach3 etc...
Andy
Old 10-17-2007, 11:29 AM
g-codeguy is on a distinguished road
Programs are for a 45 degree chamfer at .890 diameter.
.016R finishing tool
X.8539Z0
G3X.8836Z-.0062R.021
G1X1.0288Z-.0787
X1.05Z-.42
Z-?
.031R finishing tool
X.8239Z0
G3X.8748Z-.0105R.036
G1X1.0284Z-.0873
X1.05Z-.4348
Z-?
Threading cycle for a machine such as a Hardinge, Daewoo, Mori, etc.
X1.08Z.3
G76P000155Q30
G76X.9575Z-.85P570Q130R-.0358F.0714
Threading cycle for an older machine
X1.08Z.3
G76X.9575Z-.85I-.0358K.057D150F.0714A50.
This should get you in the ballpark.
Voice Your Opinion On "POLYMER CONCRETE FRAME" Thread! walter Polls 13 04-27-2012 07:19 PM
Index to "Epoxy-Granite machine bases" thread walter Epoxy Granite 13 12-01-2011 10:45 PM
V18.0 Spiral Thread post has no "Z" Output twt BobCad-Cam 11 09-09-2011 08:58 PM
Another " Moving a Tormach to a basement" Thread Scott_M Tormach PCNC 10 03-30-2007 10:08 AM
Thread not showing up in the "New Post" section Mr.Chips Forum Questions or Problems 1 10-23-2006 02:14 AM
