Old 09-30-2007, 02:26 AM
viorel26's Avatar
viorel26 is on a distinguished road
Common Variables
On Fanuc 21i-TB is there a parameter number to lock the common variables #500 to #531 so they can not be changed or deleted?
Old 10-02-2007, 11:25 AM
JMS4287 is on a distinguished road
Not That I'm Aware of...I ussually store them in a 8000 or 9000 series program and then lock those programs, and use a sub program call to reload the variables before I need them ...Just incase anybody changed anything they will always get reloaded....
example:
O0001(main program)
M98 P9000
"progam needing variables"
M30
O9000(VARIABLES LIST)
#500=??
#501=??
#502=??
etc.
M99
param 3202 bit 4 (NE9) locks 9000 series and bit 0 (NE8) locks 8000 series programs...
Old 10-02-2007, 02:02 PM
ChattaMan is on a distinguished road
That's clever.
Old 10-02-2007, 04:09 PM
viorel26's Avatar
Thank you.
Thank you for reply.Param 3290 bit #2 locks the variables 500.Good ideea with 9000 program.Thank you
Need help with IF ,THEN,AND GOTO USING COMMON VARIABLES. XRACERJB General CNC (Mill and Lathe) Control Software (NC) 2 08-31-2007 08:08 AM
How do you clear variables after the prg. is done?? theemudracer Fanuc 18 03-25-2007 09:21 PM
Variables/Macro uses.... theemudracer Fanuc 12 12-13-2006 01:45 PM
Common?to Most Surfers Bear Fadal 1 01-22-2006 02:13 AM
engraving with variables Shizzlemah Fadal 5 06-11-2005 08:13 AM
