| G-Code Programing Discuss G-code programing and problems here! |
Hello; I am looking for a few sample programs using the c-axis feature for the lathe. The equipment I will be using is Yama seiki ga-2000 series with a fanuc Oi TB controller I am looking for milling,drilling and tapping examples. I am also wondering about the difference in using either the c or h for controlling the chuck rotation? my email is pjmorand@hotmail.com Thank you |
You would be better off looking at your manuals for prog examples as each machine maker seems to use different codes for activating live tooling other than this drill tapping and basic milling are the same as turning G01 for feed you feed per rev or meters per min. you are just dealing with X, Z in a slightly different way. C usually is absolute degrees H is incremental move. ST |
| Thats the problem I am having the maker did not include any examples. The m codes are , m18 c-axis cancel m19 c-axis on m29 rigid tapping m73 revolve tool forward m74 reverse m75 stop H and c as you mentioned What G-codes are involved other than g97,g98 Thanks |
| don't know if this will work for you but this is from a fanuc control q has to be reapeted on every line r is an incremental value from x start point remember x is diametrical and y is radial substitute G88 for the tap. g88 is already rigid tap mode N6(3/64 DIA TIN COATED COBALT DRILL ) G30U0W0 M35( milling mode) M90( unclamp c axis) G0G40G80G97G98 G0G54T0606 /M33S2491 M110 ( interferance check) M8 G0C0.Z-.1Y.445 X.46 G87C0.X-.425Q300R-.025M89F3.5 C120.R0500Q300M89 C240.Q300R0500M89 G80X1.0 C0.M90 G28V0 G28H0 G30U0M35 M5 M1
__________________ If you can ENVISION it I can make it |
| This is a recent Drill and Tap program I used on our Leadwell CNC with Fanuc OiTB Control. We don't have B-Axis to cross-mill and can only Mill, Drill and Tap on the centerline in the Z direction only. Remember when milling, your finish depth will be in diameter. I tried to add notes where possible. I hope this helps. [THERE ARE THREE MILLED FLATS FOR N3...ONE EACH AT 180 DEG., 0.0 DEG, AND 270 DEG.] N3 (MILL CYLINDER FLAT) (TOOL 1.250 OD END MILL) G50 S3500 T0303 G54 M60 M5 M90 M191 G97 S424 M95 G98 G0 G28 H0 G0 C-180. G0 Z0.75 X1.7500 M8 G0 X1.0635 G1 Z-1.3 F3.4 (First pass @C180.0) G0 X1.7500 G0 Z0.75 G0 X0.752 (Finish Dia.{depth}) G1 Z-1.3 (Final pass @ C180.0) G0 X2.7500 Z0.75 (MILL SENSOR FLAT) G98 G0 C0. G0 Z0.75 X2.7500 G0 X1.0500 (Finish Dia. {Depth}) G1F6.79 G1Z-1.3 F5.0 (Final Pass @C0.0) G0X2.7500 Z0.75 (MILL AIR HOLE FLAT) G98 G0 C270. G0 Z0.75 X2.7500 G0 X1.352 (Finish Dia. {Depth}) G1F6.79 G1Z-0.700 F6.0 (Final pass @C270.0) G0X2.7500 Z0.75 M9 M95 G0 X8. G0 Z4. M1 [THERE ARE THREE CROSS-DRILLED HOLES FOR N7...2 ON C0.0 @ Z-0.25 AND Z-0.846 AND 1 ON C270.0 @ Z-0.846] N7 (#29 CROSS DRILLED HOLES) (TOOL .136 CROSS DRILL - MAIN) G50 S3500 T0505 G54 M59 M90 (C-Axis1 Mode On) G0G28H0 (Home C-Axis) G28C0.0 (C-Axis to 0.0) G0X1.475 G0Z-0.25 G97G98S3000M94 M8 G87X0.125C0.0Z-0.25Q2500F4.0M35 (Drill Peck cycle @C0.0) Z-0.846Q2500 (2nd hole on C0.0 @ Z-0.856) G80 M36 (C-Axis1 Unclamp) G0X1.452 G87X0.125Z-0.846C270.F4.0M35 (Drill Peck cycle @C270.0) G80 M36 (C-Axis1 unclamp) M95 (Spindle Stop) M91 (C-Axis1 Mode OFF) M9 G0X8.0 G0Z4.0 M1 [THERE ARE THREE CROSS-TAPPED HOLES FOR N8...2 ON C0.0 @ Z-0.25 AND Z-0.846 AND 1 ON C270.0 @ Z-0.846] N8 (8-32 TAP 1) (TOOL 8-32 TAP - CROSS) G50S3500 T0707G54 M59 M90 (C-Axis1 Mode On) G0X1.5 G0Z0.25C0.0 Z-0.25 X1.65 M65S721 (PMC-Axis Control ON) G188U-0.375Z-0.250C0.0R0.3F0.03125S721D1.05 (Tapping cycle @C0.0) Z-0.846 (2nd Tapped hole on C0.0 @ Z-0.846) M66 (PMC-Axis control OFF) M36 (C_Axis1 Unclamp) G0X1.959 C270.0 (Rotate C-Axis to C270.0) M65S721 (PMC-Axis Control ON) G188U-0.375Z-0.846C270.R0.30F0.03125S721D1.352 (Tapping cycle @C270.0) M66 (PMC-Axis control OFF) M36 (C_Axis1 Unclamp) M91 (C-Axis1 Mode OFF) M9 G0X8.0 G0Z4.0 M1 |
| Super NTJ LATHE Variable programming | mike9696 | G-Code Programing | 8 | 07-10-2007 07:42 PM |
| haas lathe programming question | pavelbure | Haas Lathes | 4 | 06-17-2007 10:17 AM |
| 4-axis, 3+2, or 4+ axis programming system? | roboticist | General CAM Discussion | 0 | 09-04-2006 01:02 PM |
| CNC Lathe programming software on Ebay | WayneHill | Product Announcements & Manufacturer News | 0 | 07-19-2005 11:21 AM |
| Programming lathe with radius numbers | mudwhump | BobCad-Cam | 1 | 06-07-2004 07:14 AM |
