| G-Code Programing Discuss G-code programing and problems here! |
| Use G92 in MDI. If you pickup center of a hole and that will be zero in MDI enter G92X0Y0 If you edge find (.200 edge finder) the left side of a piece in X use G92X-.1 hope that helps! I don't have an 850 controller, but I do have a program manual here. Also I think it works the same as the A2100 controllers. |
I used to do some programming on CNC, so i am very rusty. Do you have any sample peck drill NC programs you could let me see. I have a manual, but it is written for the experienced programmer. I just need a sample to get me started. Any help would be appreciated. Thanks, dg |
| Our Cincinnati machines here at work all have the A2100 controller. I think the programs are similar, but try this stuff at your own risk. Be careful! This will drill 2 holeS 1" apart starting at X2Y2. :G0G90 <---RAPID MODE ABSOLUTE M6T1 <---- TOOL CHANGE TOOL 1 (MSG, SPOT DRILL) <--- MESSAGE BLOCK DONT KNOW IF 850 CAN USE THESE S600M3 <---SPINDLE CLOCKWISE 600 RPM GOX2Y2Z3 <--- RAPID TO POSITION M8 <--- COOLANT ON G81Z-.25R0W.1F2.5 <--- DRILL FEED IN RAPID OUT .25 DEEP FROM R PLANE OF 0 (Z ZERO) RETRACT Z .1 FEED IS 2.5 IPM X3W.1 <--- NEXT HOLE RETARCT Z.1 G0G90 <--- CANCEL DRILL CYCLE RAPID MODE ABSOLUTE M1 <--- OPTIONAL STOP M2 <---END PROGRAM If you want to peck drill say 1/2 deep change the G81 line above to: G83Z-.5R0W.1F2.5K.1J13 G83 is peck cycle K is distance to peck J13 is peck full out. Change to J11 for chip breaker. Let me know if it helps or if you need anything else. Last edited by Chaz; 10-10-2007 at 09:58 AM. Reason: mistakes |
I came in this morning to a Spindle Drive Fault on our Cincinnati Milacron. When I try to load a tool, it faults out and spindle turns slow. Any ideas. I know what the book says to do, and that's call a service rep. Is there a way to reset spindle drive? Thanks, Dg |
| We have seen drive faults here from things liek power drops or even crashes. Normaly we can shut the machines down, including the breaker to the machine, wait a few minutes and power everthing back up. If the machine aligns properly it should be OK. I have never seen a machine based on the 850 controller. On ours the particular servo drive controller in question usualy displays an error code when there is a problem |
| does anyone have a pdf. of a cincinatti 750 operators manual? i just started working for a new company and thats what they have. im used 2 haas & fadal. my forman has been running these machines for 15 years and he is a condicending a** he expects me to be as fast at on the fly programming as he is and its pissing me off!!!!!!!!! so i thought i would try and get a copy of the manual and study it at home and try to get up to speed with him & get better than him. thanks !!!!!!!!!!!!!!!!! |
| Cincinnati Sabre 500 | leggetmachine | General Metal Working Machines | 8 | 05-15-2011 11:14 PM |
| Questions and/or Opinions about Cincinnati Sabre/Acramatic 2100 | flyinphill | General Metalwork Discussion | 17 | 10-29-2008 05:10 PM |
| Cincinnati Arrow vs Sabre | MITYDR | General Metal Working Machines | 1 | 07-20-2007 05:35 PM |
| cincinnati sabre parts | LUNCH TIME | General Metal Working Machines | 0 | 03-07-2006 09:47 PM |
| Help on Cincinnati Sabre 1000 | alexanderrt | Hard and High Speed Machining | 0 | 03-01-2006 10:30 AM |
