| G-Code Programing Discuss G-code programing and problems here! |
| I am having difficulty getting my cutter compensation to work correctly in a cam Helix The Helix changes pitch at one point and it really freaks out the Fanuc 0M control. It gives me circles like in the Post "Automatic Cutter Compensation problems" on this site. I started using I,J and then switched to R and then converted the whole thing to X,Y,Z points. I haven't had sucess yet unless I re-write it to show the moves without G41. I'll attach what I've Got now. This is On a Hardinge VMC 600 with a Fanuc 0M control Vertical Machine Hutch |
| Using G41/42 with short segments around arcs can cause the controller to stall. Most likely the change of the helix pitch is the error point. If the segments at the change point are made longer may overcome your problem. This may make your part out of specs. You may need to create a actual tool path to overcome your problems. |
| 070924-0630 EST USA chutch: I can not understand this discussion so far. Your first post indicates problems using arcs, but you provide a program illustration with straight line segments. The simplest of operations for a CNC controller to handle are straight lines. You need to find the exact point in your attached program where the problem occurs. If there is not too much lookahead the point where the program appears to stop may be close to the actual problem. Just providing us with a program with hundreds of points is not an effective way to find the problem. Without cutter comp and straight lines there are probably no invalid motions except exceeding travel limits. With cutter comp there may be some rules on invalid motions at corners. What is the code near the failure point, and what are the error messages? What do you mean by overshoot? If it means that the machine runs your program but you do not get the desired result, then where the error occurs you have to look at your code and how cutter comp works and see what geometry this produces at the cutting point. . |
One thing i have noticed is that your ramp onto the helix is not tangential at the start of the helix and your ramp on & at that point the short lines of which your spiral is composed form a "v" the maximum cutter rad at that point is .217 which may cause problems when using comp if your cutter of a greater rad. |
#11
| To Kiwi That dialog box is only to create the drawing. Once you have the drawing you generate a toolpath and then the nc file. You can do it internal and external. It is better to use compensation in control. John |
| static from hell | swarfmacdaddy | General Electronics Discussion | 8 | 02-15-2010 01:09 PM |
| I'm in CNC Hell---Somebody help me | Shinosky | Benchtop Machines | 1 | 10-28-2006 05:41 PM |
| Used Milltronics Phase 1 - Nice or run like hell?? | Stuff-Builder | Milltronics | 6 | 03-18-2006 06:41 PM |
| Made in the USA..what the hell does that mean anymore? | carbidecraters | CNCzone Club House | 150 | 10-28-2005 03:01 AM |
| I'm in Tap and Die Hell | samualt | DIY-CNC Router Table Machines | 24 | 06-02-2004 11:00 PM |
