Old 09-10-2007, 09:43 AM
nilimpa is on a distinguished road
Programming with conditionals and inputs/outputs (URGENT)
Hey guys, I have a problem.
I was assigned to do a project that involves using a CNC Machine to communicate with another device (specifically, a robotic arm).
Currently, my knowledge on CNC programming is limited to G-codes and part programming, and I have absolutely no idea how to do this.
If it's helpful, the CNC machine I'm working on is the EMCO Concept Turn 55, and I believe the software we're using is Sinumerik 840D. The hardware part of this is pretty much taken care of, for now. I was already shown the I/O ports of the machine, and have found that an LED indicator lights up when an input port receives a signal. My problem right now is how to program the machine to react to that signal.
A quick search in the forums yields some information on macro/parametric programming, and I think that might be what I'm looking for. I have a few questions:
1) Are there conditional statements in parametric programming, such as IF...ELSE?
2) Is there any way to detect a signal from another device? I would like to do something along the lines of "IF signal detected THEN start machining"
3) Is there any way to output a signal?
I would also greatly appreciate it if you guys could show me any relevant resources online..
Thanks in advance.
Old 09-10-2007, 10:42 AM
Sump Cleaner's Avatar
Sump Cleaner is on a distinguished road
Nilimpa,
Try this site. It contains all of the manuals for the 840D control. We have a Matsuura here with and 840DI control but I've never done any interfacing like this before.
The Sinumerik Macro does contain an IF... ELSE statement.
As for #2 & #3 - I'm sure ther is a way to do it but I'm not sure how. Hopfully one of these manuals will help.
http://www.automation.siemens.com/do...07_e&scope=all
JK
Old 09-10-2007, 09:27 PM
gar gar is offline
gar is on a distinguished road
070910-2122 EST USA
In a HAAS control there are M codes to work with ddiscrete inputs and outputs.
See the on-line HAAS manual for mills. M51 to turn on a relay, M61 to turn off the M51 relay. Additional codes for other relays.
M96 Is a conditional loop branch dependent upon on the state of a discrete input.
Go to www.haascnc.com
There also #-addresses relating to the discrete signals. Like #1000-#1031 for 32 inputs, and #1100-#1131 for outputs. To work with the #-addresses you need MACROS.
Old 09-22-2007, 09:55 AM
oldjohn's Avatar
oldjohn is on a distinguished road
Yes, parametric/macro programming uses If and While conditional statements, but it's not something you can learn overnight.
Old 09-22-2007, 10:43 AM
gar gar is offline
070922-1042 EST USA
nilimpa:
Did you ever solve your problem?
E-stop and enable outputs Drew Machines running Mach Software 1 06-01-2009 06:18 AM
inputs outputs sintratech Machines running Mach Software 6 04-01-2007 02:17 PM
Inputs/Outputs UKRobotics General Electronics Discussion 13 08-02-2006 09:52 PM
URGENT: 2J Quill return sping replacement -URGENT NC Cams Bridgeport and Hardinge Mills 8 02-13-2006 10:48 PM
Opto 22 / ICM outputs not working mzartop6 CamSoft Products 3 01-27-2006 10:35 PM
