| G-Code Programing Discuss G-code programing and problems here! |
It's an Okuma OSP-E100L control code: G0 X20 Z20 G50 S900 T0202 G96 S200 M3 M8 X3.8 Z.1 Z-.2 G1 X3.7614 Z-3151 F.02 This works. If i change the G50 value to S350 i get this alarm: Spindle Revolution over A side 3E8 any idea why? Thanks ahead of time.... |
| Only my guess, I think right now machine is on the high gear and I don't think you can go below 500rpm. Keep try to play with the RPM....and it is what I'm guessing then witch machine to lower gear.
__________________ The best way to learn is trial error. |
| Try these changes: (comments inserted for clarity) G90 (Absolute positioning) G0 X20 Z20 (Rapid to soft limits) G50 S350 (Set maximum spindle speed) G95 (Set feed in IPR) G97 S=3.82*200/3.8 T0202 M3 (Set starting spindle RPM to match initial X position, select Tool 2) G00 X3.8 Z.1 M8 (Rapid to initial X,Z position, coolant ON) G96 S200 (Set CSS mode) G00 Z-.2 G1 X3.7614 Z-3151 F.02 ... G97 S=3.82*200/3.7614 (last X feed pos) G00 X20 Z20 M9 This will keep the spindle from wild RPM changes (in G96 mode) when rapid traversing the X axis. |
| tl-2 program integrity error and program data error alarm #'s 212 250 need help | CNChelp | Haas Mills | 12 | 03-14-2010 08:19 PM |
| Mazatrol Program into a G Code Program | fuzzman | Mazak, Mitsubishi, Mazatrol | 14 | 02-08-2010 03:55 PM |
| Lathe program/alarm issue | kperk12345 | Okuma | 6 | 10-11-2007 01:57 AM |
| Anyone got any basic examples of a program using a subroutine/program? | Darc | CamSoft Products | 11 | 10-08-2005 11:45 PM |
| PS-012 alarm for T-15 | Mircea | General CNC (Mill and Lathe) Control Software (NC) | 0 | 03-30-2005 12:31 PM |
