Old 07-19-2007, 05:47 PM
goodplastics's Avatar
goodplastics is on a distinguished road
anyone have a Fanuc drill mate or robo drill?
I have a 1991 Fanuc Drill Mate - T model 10 with fanuc 0Mb control, I am trying to get scanvec amiable to write me a post for enroute pro 3.3 but they want an example of perfect code to compair to. I have been learning alot but so far am unable to write a sample program that is exactly correct. I am wondering if any of you guys have the same machine I have and could let me borrow a simple part program and the drawing and specifics to the part so I could recreate it in the enroute software for compairison. I only need a hole or two and a square with radiused corners and maybe a pocket millout to use as an example. I have determined that the machine doesn't like the % sign at the begining of the program and that it likes a short REM line at the begining of the program to kick off comunications without overflow error. Any help with this would be greatly appreaciated and the thank-yous would flow unceasingly from my keyboard!
Thanks,
Jason
Old 07-22-2007, 10:36 AM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Thanks,
Jason
There is information for you in your other thread.
http://cnczone.com/forums/showthread...681#post322681
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. Geof General Metalwork Discussion 47 02-01-2008 01:32 PM
Drill holes with end mill or twist drill ? Argofanatic General Metalwork Discussion 15 12-29-2006 10:05 PM
Carbide drill VS indexable drill kalmah General Metalwork Discussion 8 11-08-2006 06:48 AM
fanuc drillmate / robo drill alarm 1006 clamp goodplastics Fanuc 4 05-02-2006 09:05 PM
Can I drill AISI 1020 plate steel with a drill bit? Apples General Metalwork Discussion 2 02-01-2006 11:15 AM
