Old 04-23-2004, 11:17 AM
ljoe1969 is on a distinguished road
Arc In Z And X Plane
WHAT IS THE CODE FOR MAKING AN ARC IN A PLANE OTHER THAN THE X AND Y?
Old 04-23-2004, 11:46 AM
ger21's Avatar
G18 to switch to XZ plane
G19 to switch to YZ plane
G17 to switch back to XY plane
Still use G2 or G3. You won't use Y in the G2 or G3, you'll use X and Z
Old 04-23-2004, 11:59 AM
Rekd's Avatar
Rekd is on a distinguished road
You also need to use, (if you're using IJK method,) I and K for the X Z axis, and J and K for the Y Z axis.
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 04-23-2004, 12:17 PM
ger21's Avatar
That was implied
Old 04-23-2004, 01:21 PM
Rekd's Avatar
Implied but not expressed?
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 04-23-2004, 02:09 PM
keithorr is on a distinguished road
You also need a controller that supports circular interpolation in XZ or YZ. G-Code by itself isn't enough.
Old 04-23-2004, 02:22 PM
Rekd's Avatar
True dat!
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 04-27-2004, 09:08 PM
i got the 3 axiz board and steppers from xylotex. will that do it?
Old 04-27-2004, 09:58 PM
ger21's Avatar
What software are you using to control the machine. It's not the Xylotex, but the software that needs to di it. TurboCNC or Mach2 will both work.
Old 04-27-2004, 10:10 PM
i am using turbocnc.
  #11   Ban this user!
Old 04-27-2004, 10:32 PM
wjbzone's Avatar
wjbzone is on a distinguished road
Turbocnc supports G17, G18, G19.
Are you programming the center of a ball end mill?
Bill
single line fonts? balsaman General CAM Discussion 12 02-18-2006 12:51 PM
using vmc as a lathe ddwinn General CNC (Mill and Lathe) Control Software (NC) 7 04-25-2005 08:48 AM
construction plane and tool plane nervis1 Mastercam 9 11-05-2004 12:53 AM
Problem cutting arc with lathe. mudwhump G-Code Programing 9 05-23-2004 01:19 PM
cycles initial plane/retract plane HuFlungDung OneCNC 25 06-26-2003 08:02 PM
