Old 07-04-2007, 02:50 PM
CNC_Geek is on a distinguished road
Question Help needed on FAGOR controller
Hi Everybody !
Does anyone know which G code disables the axes stop at the end of each G-code line on FAGOR 8040 NC ? I would like the axes' speed to be constant all along the toolpath.
Thanks in advance for your help
Luis
Old 07-05-2007, 02:02 AM
Kiwi is on a distinguished road
I use a Fagor 8055M and I put G51 E0.0001 at the beginning of my code.
This is Look-Ahead with error of .0001mm and the tool dosen't hesitate.
Old 07-05-2007, 10:27 AM
g-codeguy is on a distinguished road
Not sure if this is what you are looking for, but on an 8025 control G05 is corner rounding, G07 is square corner. In G05 the movements programed in the next block are executed before the machine has reached the exact position programed in the previous block. The faser the feedrate, the greater the differance between the theoretical and actual profiles.
In G07 the CNC does not execute the next block of the program until the exact position programmed in the previous block has been reached. The theoretic and actual profiles coincide.
Some controls use an M-code for positive cornering. I didn't see one in the 8025 manual.
Old 07-10-2007, 03:50 PM
Thanks !
Thanks to both of you !
As a matter of fact, what I was looking for was the G51 function given by Kiwi. I wanted the tool speed to be constant all along the toolpath. It works just fine.
Regards
Luis
Old 10-09-2011, 01:38 PM
Tapper is on a distinguished road
Unhappy
I got the same problem whit Fagor 8055M "Lagging"
When i put G51 E0.0001, i get this Error
CNC: 0174 Cirkular interpolation not possible.
Old 10-09-2011, 02:42 PM
Originally Posted by Tapper View Post
...When i put G51 E0.0001, i get this Error
CNC: 0174 Cirkular interpolation not possible....
Helical interpolations are not possible while the Look-Ahead (G51) function is active.
HELP needed for Siemens Controller programming!! cybertool G-Code Programing 5 07-02-2008 06:46 AM
FAGOR Controller Tool Radius Problem Kiwi Fagor Automation 6 06-16-2006 10:48 PM
mori with t6- b controller sample program needed anyfish Fanuc 0 02-03-2006 05:58 AM
FAGOR 8055M 3Axis Controller Kiwi Fagor Automation 8 11-16-2004 03:53 AM
PC Based Hardware Controller Kit Needed pmartin223 General Electronics Discussion 6 06-13-2004 10:28 AM
