Old 07-03-2007, 08:55 AM
cnc-king's Avatar
cnc-king is on a distinguished road
Need help with variable programming
I need to set my top cut prog in the lathe so the operator does not have to edit the top cut program due to the fact that it is one of the 9000 series progs. I want to use variables to set the values for different type of material
and daimeters. Please look at my sample programs and let me know if this will work
thanks
O7777(BAR FEED SAMPLE)
(/UBARFEEDSAMPLE)
G10L2P6X0.0000Z8.5000
#501=3000 ( SET MAX RPM )
#502=2000 ( SET CSF )
#503=1.55 ( SET BAR DIA +.05)
#504=.005 ( SET FEED RATE )
/2M98P9000
G30U0W0
T1111
G0G18G59X-3.Z.01
M31
M69
G4P2000
G54
G1G98Z.14F50.
G4P2000
M68
G0Z.3
G30U0
G30W0
M99
O9000(END OF BAR TOP CUT)
G30U0W0
M65 ( STOP SPINDLE & COOLANT)
M31 ( INTERFERANCE OFF)
M69 ( OPEN COLLET )
G4P500 ( PAUSE )
M50 ( BAR PUSHER PUSHER NEW BAR TO TOP CUT POS)
G4P200 ( PAUSE )
M68 ( CLOSE COLLET )
G4P200 ( PAUSE )
G97S2000M3 ( START SPINDLE )
G0G59T1111 (CALL CUTOFF TOOL)
G50S#501M63 ( SET MAX RPM )
G96S#502 ( SET CONSTANT SURFACE FEET)
G0Z.0M8 ( POSITION TOOL TO TOP CUT POS )
X#503( BAR STOCK DIA +.05 )
G1G99X-.01F#504
G0X#503
G30U0
G30W0
M65
M99
If you can ENVISION it I can make it
Old 07-03-2007, 12:10 PM
cogsman1 is on a distinguished road
Looks good, BUT
The code you show should work BUT the one change you should make is out the "G0X#503" BEFORE the G96 line. This will be better for your machine. The spindle will not ramp up so fast during the rapid down to the stock. Also "X-.01" may not be low enough to drop the slug. Look at your insert raduis and go twice that size below zero.
See below.
G30U0W0
M69 ( OPEN COLLET )
G4P500 ( PAUSE )
G4P200 ( PAUSE )
G4P200 ( PAUSE )
G1G99X-.03F#504
G0X#503
G30U0
G30W0
M65
M99
Old 07-03-2007, 07:48 PM
g-codeguy is on a distinguished road
I like "cogsman1's" program better for his already stated reasons. Only thing I can add is that the G0X#503 is an unnecessary block. G30U0 will take it home...as you already know.
I do have a question. What kind of material are you running that you can run a G96S2000 for a cut-off tool? Teflon?
Old 07-03-2007, 08:25 PM
cnc-king's Avatar
thanks for the info guys
I use valenite's od groove tool as a cut off tool. I modified it so i can cut up to 2.00 dia. I only run that csf in my top cut because i am not concerned about picking the part with the part catcher or the sub spindle. the material is 2024 btw
Old 07-05-2007, 08:18 AM
*Registered User*
Bluesman is on a distinguished road
thanks
(/UBARFEEDSAMPLE)
/2M98P9000
G30U0W0
T1111
G0G18G59X-3.Z.01
M31
M69
G4P2000
G54
G1G98Z.14F50.
G4P2000
M68
G0Z.3
G30U0
G30W0
M99
G30U0W0
M69 ( OPEN COLLET )
G4P500 ( PAUSE )
G4P200 ( PAUSE )
G4P200 ( PAUSE )
G1G99X-.01F#504
G0X#503
G30U0
G30W0
M65
M99
This is what I used for our HMC's it will work on a lathe just change tool dia for Bar Stock Dia
#1=3500(FIRST SFM)
#2=.007(FIRST FEED/TOOTH-INCHES)
#3=2.0(CUTTER DIA-INCHES)
#4=5(NUMBER OF FLUTES/TEETH)
#5=ROUND[[#1*12]/[#3*3.1416]](CALCULATED RPM)
#6=[[#4*#2*#5]*25.4](CALCULATED FIRST FEED MM/M)
Then for speeds and feeds us F[#5] S[#6]
Bluesman
vARIABLE #3006 marrieche G-Code Programing 4 03-31-2007 08:31 AM
Variable autotransformer Pxsi Benchtop Machines 3 11-09-2006 01:00 AM
IF variable = bla THEN do this ELSE do that ? iMisspell G-Code Programing 21 07-30-2006 10:57 PM
Variable transformer bdillard General Electronics Discussion 8 02-20-2006 09:33 PM
variable speed??? turmite General Electronics Discussion 14 03-27-2004 01:26 PM
