Results 1 to 2 of 2
Thread: Need help with live tooling on cnc vtl
    Nov 2006
    My machine runs a Fanuc control, and is capable of macro B programming. The following program will Drill 6 holes on a 5 inch hole circle. Is there a way to write a macro to do this.
    M45
    G28 H0
    G0 T0101
    G97 G98 S1000 M13
    X5.0 Z.5 C30. M8
    G83 Z-.350 R-.400 P1000 F10.
    C90.
    C150.
    C210.
    C270.
    C330.
    G80
    G0 G99 X8.00 Z4.00 M5
    M46
    I would like to set it up the same as my other macro's, for example:
    O1000
    (HOLE CIRCLE PROGRAM)
    #1= 1000 (RPM)
    #2= 0101 (TOOL)
    #3= 10. (IPM)
    #4= 6 (NUMBER OF HOLES)
    #5= 30. (DEGREES OF FIRST HOLE)
    I am not sure if it can be done, but any help would be greatly appreaciated.
    Registered CNCRim's Avatar
    Feb 2006
    Post
    Yes, it can be done. there are few way you can mipulate these one with Do-While or you can use if and go statement.
  1. tuning and live tooling
    By fjd in forum General CAM Discussion
    Last Post: 07-10-2010, 09:28 PM
  2. TW-10 live tooling question
    By davisboys in forum General Metal Working Machines
    Last Post: 01-11-2007, 07:48 PM
  3. haas live tooling
    By tgooding in forum Haas Mills
    Last Post: 12-06-2006, 08:58 PM
  4. Takisawa Live Tooling
    By TURNING MAD in forum CNC Tooling
    Last Post: 11-29-2006, 11:26 AM
  5. RFQ small turning w/ live tooling
    By Shizzlemah in forum Employment Opportunity
    Last Post: 04-21-2005, 08:20 PM
