Old 06-22-2007, 06:10 AM
TURNER is on a distinguished road
Calculate Circle Centre
Hi to all,
Can any body help, I need a formula to calculate X and Y coords of circle centre. The known data is point X1,Y1 and X2,Y2 and R (RADIUS).
From this i need to find Xc,Yc
Thanks.
Turner
Old 06-22-2007, 08:49 AM
bborb is on a distinguished road
One formula won't calculate BOTH "X" and "Y"
If you just need a start to figure it out, any math referencing chords of a circle will help tremendously.
Old 06-22-2007, 09:06 AM
Andre' B is on a distinguished road
Because there are two possible centers you also need to know which direction (clockwize/counterclockwize) you are going when you move from (x1,y1) to (x2,y2).
Old 06-22-2007, 02:23 PM
Eurisko is on a distinguished road
The math isn't pretty, but here's a link to the answer:
http://mathforum.org/library/drmath/view/53179.html
Any good cad program can solve this problem graphically.
Given: 2 points (X1,Y1) & (X2,Y2) on a circle of radius R.
Draw a circle of radius R centered at (X1,Y1)
Draw another circle of radius R centered at (X2,Y2)
The points of intersection of these circles are the possible centers. (XC,YC)
Old 06-26-2007, 04:21 AM
anorec is on a distinguished road
To calculate circle center isn't very easy... I made a little software to 'convert' a Gcode file to DXF file. Just import DXF in any CAD software and pick circle centers or any other informations you need...
Look here
Hope this can help
Old 07-10-2007, 06:39 AM
Kiwi is on a distinguished road
Turner
Attached is a program I'm working on, still a long way to go but may help with your calculating.
Some features are locked.
Old 07-10-2007, 08:39 AM
oldjohn's Avatar
oldjohn is on a distinguished road
Here:
Old 07-18-2007, 01:31 PM
Stu_M3 is on a distinguished road
Formua Circle passing 2 points
Point 1 x coord = A
POINT 1 Y COORD = B
POINT 2 X COORD = D
POINT 2 Y COORD = E
CIRCLE RADIUS = F
WHEN THE CIRCLE IS LEFT OF THE LINE FROM POINT P1 TO POINT P2 G=-1
C=F
H=D-A
I=E-B
J=√(H * H + I * I)
K=ACS(H/J)
IF 0>I THEN K = -K
ACS((C*C+J*J-F*F)/2/C/J)
M=A+C*COS(K+G*L)
N=B+C*SIN(K+G*L)
CIRCLE X COORD = M+ SGN M * .005
CIRCLE Y COORD = N+ SGN N *.005
Old 07-18-2007, 04:25 PM
I don't see what 'L' represents.
Is the L missing from this line?
L = ACS((C*C+J*J-F*F)/2/C/J)
Old 07-19-2007, 02:15 AM
Quite correct, sorry about that. wrote it down in a hurry.
  #11   Ban this user!
Old 07-19-2007, 05:43 AM
BlueChip's Avatar
BlueChip is on a distinguished road
Trig Kalculator
Trig Kalculator from Kentech Inc. will easily perform this calc and many others ... $95.
Info and demo at www.KentechInc.com
  #12   Ban this user!
Old 07-19-2007, 06:44 AM
Looking at the KentechInc web page, it appears like their Kalculator is limited to maximum 90deg arcs.
Off centre turning Integrex General Metalwork Discussion 0 04-10-2007 10:35 PM
Kitamura My Centre 2c scappini Mechanical Calculations/Engineering Design 0 07-10-2006 07:34 PM
how to calculate flex dertsap Mechanical Calculations/Engineering Design 14 04-17-2006 06:22 PM
Calculate resistor value for g210 ??????? Biggermens Gecko Drives 0 04-25-2005 02:09 PM
How do I calculate this? CNCadmin Mechanical Calculations/Engineering Design 2 02-05-2005 09:24 AM
