Old 06-18-2007, 09:16 PM
cncuser1 is on a distinguished road
Tool Length offset?
I am using Mach3.
The post-processesor Inserts a G49 ( Cancel tool length offset) at the beggining of the G-code.
I manually change tools
It seems strange that it gets canceled and is not re-instated (G43)anywhere.
Can someome tell me how Tool length offset this (G49&G43)is dealt with normally?
Old 06-19-2007, 08:18 AM
atex57 is on a distinguished road
g43
You must give the g43? at m6t? point in your program.As an example with EMC from which Mach is copied with a manual change machine:
m1 (pause machine)
m6t6 (1/2 CEM on my machine)
g43h6 (offset length of 1/2 CEM)
# (G codes)
g49 (cancels tool length compensation)
Old 08-30-2007, 08:37 PM
bob@apc is on a distinguished road
post processors can be set-up to cancel or preset modals. can cycles, cutter comp, abs or inc postioning ect, ect. i personally dont use too many of these features as we are a small shop and we have just a couple foks that get into the programs. if i were in a very large shop i might use the features to preset the machine just so i know my programs will run correctly from the start. you never know what the last guy or his program might have left in the machine as far as modals or cycles that may give you headaches.
Old 08-30-2007, 08:59 PM
Chuck Reamer's Avatar
Chuck Reamer is on a distinguished road
My Mach 3 post does the same thing, I just put in a G43 after my tool changes when im editing the right tool number from my setup page.
Live free or die
G43.1 - Tool Axis Direction Tool Length Compensatioin EngTech Mazak, Mitsubishi, Mazatrol 8 12-06-2007 04:01 AM
Tool length detection PsyKotyk LinuxCNC (formerly EMC2) 0 03-07-2007 08:47 AM
NC reading tool length from offset page, not data page..? RMagnusson Mazak, Mitsubishi, Mazatrol 1 03-21-2006 04:07 PM
Tool length sensing! Swede FlashCut CNC 15 10-12-2005 07:51 PM
