Old 06-17-2007, 07:18 AM
hutchndi is on a distinguished road
Alternate G codes?
As I am new to gcode, I am doing allot of reading up and trial and error in the learning proccess. I go through the time to try to get the code written just right, and when I have a problem and show it to the programmer, he whips out code that is barely recognisable (to me), but works just fine. For instance G01 he may just write as G1. He also told me how I dont really need to write out full x-y coordinants in every block as I was doing, at least not in incremental.
Is this typical or special code for the machines that we use? (ESAB) I cant find "G1" in any of the texts I have on codes, or in the ESAB manuals.
Example code that works:
G91
G00 X0 Y.5
G42
M70
G1 X.5
G1 Y-.4
G1 X20
G1 Y2.75
G1 X-20 Y-2.25
M73
M69
russ
Old 06-17-2007, 09:29 AM
gar gar is offline
gar is on a distinguished road
070617-0908 EST USA
hutchndi:
In the parsing of fields (like G01) into sub-parts ( G or M, and a number) some portion of the field is extracted, in this case the single alpha character is used to identify the function of the following numeric value. In the case of numeric values leading zeros are ignored. Thus, 00001, or 01, is the same as 1. So G01 and G1 produce the same result.
In a typical G-code system you will find a non-numeric character, such as A, a, R, #, X, x, (, DPRNT, etc. preceeding a numeric field (in the case of DPRNT it is more complex). The non-numeric identifies what action is to be taken with the following numeric field.
Old 06-17-2007, 10:22 AM
Al_The_Man's Avatar
Also in order to save memory on systems that short on mem. size, check for commands that are modal (global).
Like not repeating the G1, once it is entered, the control stays in G1 until replaced by G0 or ?
So in your code you only need it on the G1 X.5
Old 08-18-2009, 04:57 AM
Klaus Eskesen is on a distinguished road
Hi There
Does any one know anything about G188 rigdig tapping Fanuc 31 (Muratec MT 20) right side of machine, the tap turnes the wrong way ?
klaus
Alternate Motor Pulley? giantcake Shopmaster/Shoptask 2 01-02-2008 06:35 PM
gas prices and alternate forms of transportation CNCadmin CNCzone Club House 35 07-21-2006 10:00 PM
80/20 Alternate jbuskirk 80/20, TSLOTS and other Aluminum Framing Systems 1 11-04-2004 08:21 AM
Alternate Linear Rails?? ehiebert DIY-CNC Router Table Machines 12 10-02-2003 09:36 AM
Alternate Z-axis designs chuckknigh DIY-CNC Router Table Machines 4 04-29-2003 01:24 PM
