Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: SketchUp exporting as DXF then ACE to Gcode
    ProDrawerCom
    Apr 2006
    G00 Z0.1000
    G00 X-1851.7656 Y992.9758
    G01 Z-0.2500
    G01 X-1846.7656 Y992.9758 Z-0.2500
    G00 Z0.1000
    G01 Z-0.5000
    G01 X-1851.7656 Y992.9758 Z-0.5000
    G01 X-1846.7656 Y992.9758 Z-0.5000
    G00 Z0.1000
    G01 Z-0.7500
    These are just a few lines of the code I get when I convert a file exported as DXF from SketchUp into ACE. The problem is that the object is nothing like the code (see pic with dims). What am I doing wrong?
    Attached Thumbnails Attached Thumbnails SketchUp exporting as DXF then ACE to Gcode-plate.jpg
    Registered Bubba's Avatar
    Mar 2004
    LaGrange, GA USA
    Looks like you told Ace, that you were metric!
    Also, where is the origin of your drawing (x0 y0)
    Did you do anything to offset the path for the diameter (radius) of your cutter. Ace will follow the path and doesn't know about offsets.
    And for a piece that is .417 thick, why are you cutting .750 deep?
    Just a few questions to help you think about what is going on:})
    Art
    ProDrawerCom
    Apr 2006
    Quote Originally Posted by Bubba View Post
    I checked my drawing on SketchUp and saw that I had, in fact, selected mm instead of inches. It didn't matter to me when I was drawing it. I just wanted an object with some detail to test.
    So I changed it to inches and ran it through ACE again. It didn't change the gcode at all.
    And besides, if you look at the numbers, there's no conversion apparent. The object is 5" long. The metric equivalent of that would be roughly 5 x 27mm or 135mm. The numbers for X movement are 4 digits! So that makes no sense.
    As far as the depth of cut- I didn't plug in anything. I just drew the object, transported it to my desktop as dxf and ran it through ACE.
    Mar 2004
    LaGrange, GA USA
    Again, I go back to WHERE is X0,Y0 in the drawing?
    I often draw stuff "out in space", but when I cam it, it has to have a reference to an origin.
    Depending on condition, I might make the lower left corner of your piece as X0,Y0
    If you have that point "out in space" some where, you very well could get the results you are talking about. I am not familiar with SketchUp, but still you need an origin.
    Art
    Mar 2003
    Shelby Twp, MI....USA
    Can you post the .dxf?
    ProDrawerCom
    Apr 2006
    The DXF file
    Quote Originally Posted by ger21 View Post
    Here is the file. And unfortunately I must leave this great forum and cannot return for 24-48hrs.
    Attached Files Attached Files
    Mar 2003
    ACE is looking for a simple 2D .dxf. Yours is a 3D .dxf, consisting of triangular faces as well as lines and arcs. There are also lines running vertically at all endpoints, including the segmented arc of the pocket. Not sure if you can get Sketchup to output a "clean" 2D .dxf.
    Also, as was mentioned, you're part is at ~-1800X, and ~992 Y
    Here's you're .dxf with all the extra stuff cleaned out, and moved to 0,0. Should work better for you.
    ProDrawerCom
    Apr 2006
    Nope
    I'm probably doing something wrong. When I took your cleaned up file and ran it through ACE-- it still produced dozens of lines of code, way more than I would expect MACH to need. And they didn't look logical for the object to be created. Going to go run it and see.
    http://wwwProjectCNC.wordpress.com
    ProDrawerCom
    Apr 2006
    DXF straight to MACH
    I realized after running your cleaned up file in MACH that you probably expected me to import it to MACH. Instead I ran it through ACE and then ran the resulting gcode in MACH. It certainly did not cut the object I drew in SketchUp. Then I realized I could import your DXF file directly into MACH. So I did. It looked more like what I think gcode would look like. But it still wasn't right. For one thing the huge negative numbers were still there. I've learned a lot with this thread. Probably the most important thing is to orient the object to zero in SketchUp. Otherwise you get ridiculous numbers. I'll get there.
    http://www.ProjectCNC.wordpress.com
    Mar 2003
    I checked and found something I didn't see before. A duplicate in the .dxf, very, very far away. Try this one.
    For some reason, when I used the optimize option in ACE, it double cut some of the inside cuts. Even though it's free, ACE leaves a bit to be desired. I got much better results, and more control with LazyCAM, included free with Mach3.
    ProDrawerCom
    Apr 2006
    Will see
    I'll give your new file a whirl next chance I get.
    A few days ago, after downloading ACE, I learned about the existence of LazyCAM. Haven't had a chance to try it yet. Certainly would expect it to work better with MACH.
    ProDrawerCom
    Apr 2006
    The drawing and the foam
    Hmm. What a mess. (The bit is 1/4")
    Attached Thumbnails Attached Thumbnails SketchUp exporting as DXF then ACE to Gcode-plate.jpg   SketchUp exporting as DXF then ACE to Gcode-foam.jpg
  • Page 1 of 2 12 LastLast
    1. SketchUp 2 Solidworks
      By chojin in forum Solidworks
      Last Post: 01-07-2012, 07:07 PM
    2. Anyone exporting from Corel Draw 10?
      By ShayArnett in forum SheetCam
      Last Post: 05-27-2006, 03:52 PM
    3. Sketchup..... anyone using it
      By plane magic in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 03-15-2006, 07:02 PM
    4. Replies: 0
      Last Post: 03-10-2005, 01:46 PM
