Old 06-12-2007, 09:40 AM
wyobmf is on a distinguished road
Can anyone help programing a Fagor PLC 64?
I have a Matsuura MC-500V it was retrofitted with fagor controls and uses a PLC 64 to do the automatic tool changes. I found a hard copy of the ladder logic and I have the software, Just need some tips on how to get started, I am not that familiar with programing PLC's with DOS software.
Old 06-12-2007, 10:36 AM
Al_The_Man's Avatar
What make is the PLC 64? Do you want to modify the program?
My experience with Fagor PLC's has been programming in mnemonic format.
Old 06-12-2007, 12:06 PM
Oh yeah, I forgot to say it lost its program when it was powered down for a long period of time, and I don't have a back-up so it needs reprogramed or changed out with a better PLC.
The PLC-64 is made by fagor.
Old 06-12-2007, 12:13 PM
Al_The_Man's Avatar
What is the Fagor control that is on the machine?
If you have the listing then it should be possible to type it in to a PC and download it to the PLC, I believe Fagor supply a Terminal program for doing this, also you may be able to use a modem program, but you have to know the serial protocol the PLC is set to.
Is the PLC built into the CNC or stand alone?
Also Fagor support are usually very helpfull.
Programing AUX buttons George C AjaxCNC Control Products 3 02-10-2007 01:33 PM
C-Hook programing Russler Mastercam 1 01-14-2007 08:56 AM
Programing book mikeh Laser Engraving & Cutting Machines 0 03-03-2006 05:47 PM
CAM programing kenlambert G-Code Programing 1 02-03-2006 12:03 AM
Lathe programing help smitty TurboCNC 24 06-23-2003 10:39 AM
