| G-Code Programing Discuss G-code programing and problems here! |
I am trying to write a program to engrave sequential 5 digit serial numbers. I am new to parametric programming and would greatly appreciate any suggestions or examples I can work with. Thank you, Rob |
| your question very broad.... alot of open over end, need more detail what you want to do such as engrave on flat, on arc, 3d, what's the font ..... etc. If just a simple engrave, I remember under unlimitprogramming.com had the program you looking for.
__________________ The best way to learn is trial error. |
| I'm engraving flat plates with the plainest font I can find. These are nothing special. They get welded to a weldment and painted over. Right now they are getting done on a pantograph and really look like crap. I tried looking up unlimitprogramming.com and came up with server not found |
| Assuming you have subs for the characters 0,1,...,9 that use the current position as the start of the character and leave the spindle at the start position of the next character and are numbered 8000 for 0, 8001 for 1, etc.. . . . #100=#100+1; (Increment serial number) #101=#100; #102=0; (10000 DIGIT) #102=FIX[#101/10000]; #101=[#101-[#102*10000]]; G65 P[8000+#102]; (1000 DIGIT) #102=FIX[#101/1000]; #101=[#101-[#102*1000]]; G65 P[8000+#102]; (100 DIGIT) #102=FIX[#101/100]; #101=[#101-[#102*100]]; G65 P[8000+#102]; (10 DIGIT) #102=FIX[#101/10]; #101=[#101-[#102*10]]; G65 P[8000+#102]; (1 DIGIT) G65 P[8000+#101]; . . . |
| Have you considered using a cam program for engraving? GSimple (http://www.gsimple.eu) is free and it can engrave text. The fonts are primitive (and most small characters are missing - I got bored of defining characters) but the program is open and you can define/redifine the fonts as you like. There is an example (http://www.gsimple.eu/ex8/ex8.html) in the web site. If you need more information on defining fonts, please let me know |
| I found this under http://www.cncci.com/resources/tips/engrave.htm CNC Tip: Disclaimer: CNC Concepts, Inc. accepts no responsibility for the use or misuse of techniques shown in this web page. We simply publish information we feel will be of interest to CNC users. In all cases, the reader is totally responsible for considering the implications, good and bad, of implementing one or more of the techniques we show. A letter engraving custom macro by Bruce Litton Here is a letter engraving program that will engrave the letters A-Z (any size) for any Fanuc or Fanuc compatible control having custom macro B. The control system we currently have is the Yasnac MX3, (programs should work on Fanuc 10m,11m,16m,18m controls). Without the control option for scaling the task of making letters of different size was challenge! Instructions for use:. O7000 is an example program that engraves the word "HELLO". We'll use it to explain the use of variables: % O7000(MASTER ENGRAVING PROGRAM) G90G54J1 N10M3S8000 G90G0X-.2Y0. M8 G43H20Z3. #503=1.000 #500=[#503/1.782] #501=.100 #502=1.000 G65P7001A8.0B-0.02C15.0D40.0E1.0 (H) G65P7001A5.0B-.02C15.0D40.0E1.0 (E) G65P7001A12.0B-.02C15.0D40.0E1.0 (L) G65P7001A12.0B-.02C15.0D40.E01.0 (L) G65P7001A15.0B-.02C15.0D40.0E0.0 (O) N20M98P8998 M30 % NOTE: You can keep from having to retype all of the commands in these programs by using your Internet browser's copy function. Simply highlight the program, copy it, and then open your word processor or CNC text editor. Use the paste function to bring the program into your text editor. While there will be some editing to do (you'll likely have to eliminate some funny characters and add carriage returns), this will save a lot of typing! Understanding program O7000 Program O7000 contains instructions and calculations for the CNC control. Variables used in G65 commands: A=Code number for letter (0=SPACE, 1.-A, 2.-B, 3.-C, etc., see full list below) B=Z depth from program zero C=Plunging feedrate for the Z axis D=XY feedrate E=Step over for next letter? (1.=YES,0.=NO) #503 before the G65 commands is the letter height (1.0 inch in the example) #500, #501, #502 set the width and aspect ratio for the letters. You can leave them as shown in the example. The command "G65P7001A8.0B-0.02C15.0D40.0E1.0" will machine the letter H (see code list for A word below). It will be machined 0.02 deep in Z, plunged at 15.0 ipm and machined (XY) at 40.0 ipm. The E1.0 specifies that the machine must move over by the letter spacing to get ready for machining the next letter. If E is set to zero (as it should be after your last letter), there will be no move over after the letter is machined. Code numbers are as follows: SPACE-0. A-1. B-2. C-3. D-4. E-5. F-6. G-7. H-8. I-9. J-10. K-11. L-12. M-13. N-14. O-15. P-16. Q-17. R-18. S-19. T-20. U-21. V-22. W-23. X-24. Y-25. Z-26. (Note that you must include a decimal point after each code number in the A word.) The lettering program Program O7001 contains all the lettering movements. % O7001(LETTER PROGRAMS) IF[#1EQ0.]GOTO100 IF[#1EQ1.]GOTO1 IF[#1EQ2.]GOTO2 IF[#1EQ3.]GOTO3 IF[#1EQ4.]GOTO4 IF[#1EQ5.]GOTO5 IF[#1EQ6.]GOTO6 IF[#1EQ7.]GOTO7 IF[#1EQ8.]GOTO8 IF[#1EQ9.]GOTO9 IF[#1EQ10.]GOTO10 IF[#1EQ11.]GOTO11 IF[#1EQ12.]GOTO12 IF[#1EQ13.]GOTO13 IF[#1EQ14.]GOTO14 IF[#1EQ15.]GOTO15 IF[#1EQ16.]GOTO16 IF[#1EQ17.]GOTO17 IF[#1EQ18.]GOTO18 IF[#1EQ19.]GOTO19 IF[#1EQ20.]GOTO20 IF[#1EQ21.]GOTO21 IF[#1EQ22.]GOTO22 IF[#1EQ23.]GOTO23 IF[#1EQ24.]GOTO24 IF[#1EQ25.]GOTO25 IF[#1EQ26.]GOTO26 (A LETTER PROGRAM) N1G91G0X[#500*.2203]Y[#500*.118] G90G0Z#501 G90G1Z#2F#3 G91G1X[#500*.7796]Y[#500*1.782]F#7 X[#500*.7796]Y-[#500*1.782] G90G0Z#502 G91G0X-[#500*.4018]Y[#500*.9186] G90G0Z#501 G90G1Z#2F#3 G91G1X-[#500*.7554]F#7 G90G0Z#502 G91G0X-[#500*.6222]Y-[#500*1.0366] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (B LETTER PROGRAM) N2G91G0X[#500*.1923]Y[#500*.118] G90G0Z#501 G90G1Z#2F#3 G91G1Y[#500*1.782]F#7 X[#500*1.041] G2R[#500*.4179]J-[#500*.4179]Y-[#500*.8358] G1X-[#500*1.041] G90G0Z#502 G91G0Y-[#500*.9462] G90G0Z#501 G90G1Z#2F#3 G91G1X[#500*1.1422]F#7 G3R[#500*.4731]J[#500*.4731]Y[#500*.9462] G90G0Z#502 G91G0X-[#500*1.3345]Y-[#500*1.0642] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (C LETTER PROGRAM) N3G91G0X[#500*1.3288]Y[#500*.1719] G90G0Z#501 G90G1Z#2F#3 G91G1 G2R[#500*.891]I-[#500*.3288] J[#500*.828] Y[#500*.828] X-[#500*1.2198]F#7 G2R[#500*.891]I[#500*.891]X[#500*1.2198]Y[#500*.828] G90G0Z#502 G91G0X-[#500*1.3288]Y-[#500*1.828] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (D LETTER PROGRAM) N4G91G0X[#500*.1129]Y[#500*.118] G90G0Z#501 G90G1Z#2F#3 G91G1Y[#500*1.782]F#7 X[#500*.633] G2R[#500*.891]J-[#500*.891]Y-[#500*1.782] G1X-[#500*.633] G90G0Z#502 G91G0X-[#500*.1129]Y-[#500*.118] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (E LETTER PROGRAM) N5G91G0X[#500*1.5895]Y[#500*.118] G90G0Z#501 G90G1Z#2F#3 G91G1X-[#500*1.1791]F#7 Y[#500*1.782] X[#500*1.1791] G90G0Z#502 G91G0X-[#500*.4535]Y-[#500*.8319] G90G0Z#501 G90G1Z#2F#3 G91G1X-[#500*.7256]F#7 G90G0Z#502 G91G0X-[#500*.4104]Y-[#500*1.068] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (F LETTER PROGRAM) N6G91G0X[#500*.2474]Y[#500*.118] G90G0Z#501 G90G1Z#2F#3 G91G1Y[#500*1.782]F#7 X[#500*1.5051] G90G0Z#502 G91G0X-[#500*.7306]Y-[#500*.891] G90G0Z#501 G90G1Z#2F#3 G91G1X-[#500*.7744]F#7 G90G0Z#502 G91G0X-[#500*.2474]Y-[#500*1.009] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (G LETTER PROGRAM) N7G91G0X[#500*1.4273]Y[#500*1.009] G90G0Z#501 G90G1Z#2F#3 G91G1X[#500*.4636]F#7 G2R[#500*.891]X-[#500*1.782]I-[#500*.891] G2R[#500*.891]I[#500*.891]X[#500*1.2891]Y[#500*.797] G90G0Z#502 G91G0X-[#500*1.3981]Y-[#500*1.806] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (H LETTER PROGRAM) N8G91G0X[#500*.2587]Y[#500*.118] G90G0Z#501 G90G1Z#2F#3 G91G1Y[#500*1.782]F#7 G90G0Z#502 G91G0X[#500*1.4825] G90G0Z#501 G90G1Z#2F#3 G91G1Y-[#500*1.782]F#7 G90G0Z#502 G91G0Y[#500*.891] G90G0Z#501 G90G1Z#2F#3 G91G1X-[#500*1.4825]F#7 G90G0Z#502 G91G0X-[#500*.2587]Y-[#500*1.009] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (I LETTER PROGRAM) N9G91G0X[#500*.4908]Y[#500*.118] G90G0Z#501 G90G1Z#2F#3 G91G1X[#500*1.0182]F#7 G90G0Z#502 G91G0X-[#500*.5091] G90G0Z#501 G90G1Z#2F#3 G91G1Y[#500*1.782]F#7 G90G0Z#502 G91G0X-[#500*.5091] G90G0Z#501 G90G1Z#2F#3 G91G1X[#500*1.0182]F#7 G90G0Z#502 G91G0X-[#500*1.5091]Y-[#500*1.8999] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (J LETTER PROGRAM) N10G91G0X[#500*.9405]Y[#500*1.9] G90G0Z#501 G90G1Z#2F#3 G91G1X[#500*.7128]F#7 G90G0Z#502 G91G0X-[#500*.3564] G90G0Z#501 G90G1Z#2F#3 G91G1Y-[#500*1.3067]F#7 G2R[#500*.4752]I-[#500*.4752]X-[#500*.9504] G90G0Z#502 G91G0X-[#500*.3465]Y-[#500*.5932] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (K LETTER PROGRAM) N11G91G0X[#500*.4174]Y[#500*.118] G90G0Z#501 G90G1Z#2F#3 G91G1Y[#500*1.782]F#7 G90G0Z#502 G91G0Y-[#500*.891] G90G0Z#501 G90G1Z#2F#3 G91G1X[#500*1.0145]Y[#500*.891]F#7 G90G0Z#502 G91G0X-[#500*.7972]Y-[#500*.7001] G90G0Z#501 G90G1Z#2F#3 G91G1X[#500*.9478]Y-[#500*1.0818]F#7 G90G0Z#502 G91G0X-[#500*1.5825]Y-[#500*.118] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (L LETTER PROGRAM) N12G91G0X[#500*1.4625]Y[#500*.118] G90G0Z#501 G90G1Z#2F#3 G91G1X-[#500*.9251]F#7 Y[#500*1.782] G90G0Z#502 G91G0X-[#500*.5374]Y-[#500*1.9] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (M LETTER PROGRAM) N13G91G0X[#500*.3317]Y[#500*.118] G90G0Z#501 G90G1Z#2F#3 G91G1Y[#500*1.782]F#7 X[#500*.6682]Y-[#500*1.782] X[#500*.6682]Y[#500*1.782] Y-[#500*1.782] G90G0Z#502 G91G0X-[#500*1.6682]Y-[#500*.118] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (N LETTER PROGRAM) N14G91G0X[#500*.2705]Y[#500*.118] G90G0Z#501 G90G1Z#2F#3 G91G1Y[#500*1.782]F#7 X[#500*1.4589]Y-[#500*1.782] Y[#500*1.782] G90G0Z#502 G91G0X-[#500*1.7294]Y-[#500*1.9] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (O LETTER PROGRAM) N15G91G0X[#500*1.6364]Y[#500*.7544] G90G0Z#501 G90G1Z#2F#3 G91G1Y[#500*.5091]F#7 G3R[#500*.6364]I-[#500*.6364]X-[#500*1.2728] G1Y-[#500*.5091] G3R[#500*.6364]I[#500*.6364]X[#500*1.2728] G90G0Z#502 G91G0X-[#500*1.6364]Y-[#500*.7544] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (P LETTER PROGRAM) N16G91G0X[#500*.4918]Y[#500*.118] G90G0Z#501 G90G1Z#2F#3 G91G1Y[#500*1.782]F#7 X[#500*.5722] G2R[#500*.4440]J-[#500*.4440]Y-[#500*.8880] G1X-[#500*.5722] G90G0Z#502 G91G0X-[#500*.4918]Y-[#500*1.0119] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (Q LETTER PROGRAM) N17G91G0X[#500*1.714]Y[#500*.118] G90G0Z#501 G90G1Z#2F#3 G91G1X-[#500*.4700]Y[#500*.4700]F#7 G90G0Z#502 G91G0X[#500*.3923]Y[#500*.1664] G90G0Z#501 G90G1Z#2F#3 G91G1Y[#500*.5091]F#7 G3R[#500*.6364]I-[#500*.6364]X-[#500*1.2728] G1Y-[#500*.5091] G3R[#500*.6364]I[#500*.6364]X[#500*1.2728] G90G0Z#502 G91G0X-[#500*1.6364]Y-[#500*.7544] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 ( R LETTER PROGRAM) N18G91G0X[#500*.4129]Y[#500*.118] G90G0Z#501 G90G1Z#2F#3 G91G1Y[#500*1.782]F#7 X[#500*.7934] G2R[#500*.3807]J-[#500*.3807]Y-[#500*.7614] G1X-[#500*.7934] G90G0Z#502 G91G0X[#500*.6739] G90G0Z#501 G90G1Z#2F#3 G91G1X[#500*.5001]Y-[#500*1.0205]F#7 G90G0Z#502 G91G0X-[#500*1.5870]Y-[#500*.118] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (S LETTER PROGRAM) N19G91G0X[#500*1.6543]Y[#500*1.6772] G90G0Z#501 G90G1Z#2F#3 G91 G3R[#500*.891]I-[#500*.5929]J-[#500*.6650]X-[#500*.6682]Y[#500*.2227]F#7 G3R[#500*.4455]J-[#500*.4455]Y-[#500*.891] G1X[#500*.2572] G2R[#500*.4469]I-[#500*.0359]J-[#500*.4455]X[#500*.4109]Y-[#500*.4455] G2R[#500*.4469]I-[#500*.4469]X-[#500*.4109]Y-[#500*.4455] G1X-[#500*.3100] G2R[#500*.891]I[#500*.0263]J[#500*.8906]X-[#500*.5877]Y[#500*.2450] G90G0Z#502 G91G0X-[#500*.3456]Y-[#500*.3630] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (T LETTER PROGRAM) N20G91G0X[#500*1.]Y[#500*.118] G90G0Z#501 G90G1Z#2F#3 G91G1Y[#500*1.782]F#7 G90G0Z#502 G91G0X-[#500*.891] G90G0Z#501 G90G1Z#2F#3 G91G1X[#500*1.782]F#7 G90G0Z#502 G91G0X-[#500*1.891]Y-[#500*1.9] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (U LETTER PROGRAM) N21G91G0X[#500*1.7637]Y[#500*1.9] G90G0Z#501 G90G1Z#2F#3 G91G1Y-[#500*1.0182]F#7 G2R[#500*.7637]I-[#500*.7637]X-[#500*1.5274] G1Y[#500*1.0182] G90G0Z#502 G91G0X-[#500*.2362]Y-[#500*1.9] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (V LETTER PROGRAM) N22G91G0X[#500*1.6682]Y[#500*1.9] G90G0Z#501 G90G1Z#2F#3 G91G1X-[#500*.6682]Y-[#500*1.782]F#7 X-[#500*.6682]Y[#500*1.782] G90G0Z#502 G91G0X-[#500*.3317]Y-[#500*1.9] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (W LETTER PROGRAM) N23G91G0X[#500*1.8591]Y[#500*1.9] G90G0Z#501 G90G1Z#2F#3 G91G1X-[#500*.3500]Y-[#500*1.782]F#7 X-[#500*.5091]Y[#500*1.782] X-[#500*.5091]Y-[#500*1.782] X-[#500*.3500]Y[#500*1.782] G90G0Z#502 G91G0X-[#500*.1408]Y-[#500*1.9] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (X LETTER PROGRAM) N24G91G0X[#500*1.8909]Y[#500*.118] G90G0Z#501 G90G1Z#2F#3 G91G1X-[#500*1.782]Y[#500*1.782]F#7 G90G0Z#502 G91G0X[#500*1.782] G90G0Z#501 G90G1Z#2F#3 G91G1X-[#500*1.782]Y-[#500*1.782]F#7 G90G0Z#502 G91G0X-[#500*.109]Y-[#500*.118] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (Y LETTER PROGRAM) N25G91G0X[#500*1.6615]Y[#500*1.9] G90G0Z#501 G90G1Z#2F#3 G91G1X-[#500*.6615]Y-[#500*.882]F#7 Y-[#500*.8909] G90G0Z#502 G91G0Y[#500*.8909] G90G0Z#501 G90G1Z#2F#3 G91G1X-[#500*.6615]Y[#500*.882]F#7 G90G0Z#502 G91G0X-[#500*.3385]Y-[#500*1.9] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (Z LETTER PROGRAM) N26G91G0X[#500*1.891]Y[#500*.118] G90G0Z#501 G90G1Z#2F#3 G91G1X-[#500*1.782]F#7 X[#500*1.782]Y[#500*1.782] X-[#500*1.782] G90G0Z#502 G91G0X-[#500*.109]Y-[#500*1.9] IF[#8EQ1.]GOTO100 IF[#8EQ0.]GOTO200 (STEP OVER PROGRAM) N100G90G0Z#502 G91G0X[#500*2.0000] N200M99 %
| I am trying to use the letter engraving Macro and have found that the letter "C" has an error of some kind. I'm using this on a Haas control and all the other letters are OK. Does someone have the correct version of "C". Thanks Last edited by JWK42; 09-13-2007 at 07:41 AM. |
| 070912-1611 EST USA JWK42: Just go into the subroutine for the "C" and figure out what is wrong and fix it. Pick some working characters "O", "o", "0", "D" and see what the code is and pattern your corrections from this background information. This should be an easy do-it-yourself project. . |
#12
| CNC Program Needed using Fanuc/G34 | Wedge lover | Employment Opportunity | 1 | 05-28-2007 01:18 PM |
| Newbe - Program Help needed | deleteallusers | Mechanical Calculations/Engineering Design | 3 | 04-10-2007 01:36 PM |
| First Program - Help Needed | TZ250 | Milltronics | 15 | 03-26-2007 12:38 AM |
| Program needed for waterjet | Traceman | CNC Plasma and Waterjet Machines | 0 | 04-25-2006 12:53 PM |
| EZ Track DX Program Needed | Monk | Bridgeport and Hardinge Mills | 5 | 08-08-2005 07:25 PM |
