Old 05-18-2007, 10:03 AM
saxman727 is on a distinguished road
Offsetting the Cutter
I digitized a part using a 0.5 diameter ball. Now I'd like to cut it using a 0.5625 cutter ball. Is there any G-code I can use to do this? I looked for some in my book, and I don't see anything that seems to do what I want.
Thanks in advance!
Old 05-18-2007, 03:53 PM
gar gar is offline
gar is on a distinguished road
070518-1539 EST USA
Depends upon the number of points you obtained, the .25 radii that may exist, the path you want to follow, and desired accuracy.
Try using cutter comp, and the cutter ball dia - the probe ball dia for the definition of your tool diameter.
For your values you basically need to shift the center of the cutting tool 0.03125 away from the surface perpendicular to the surface.
How do I use a dove tool cutter & slot cutter bobby1 BobCad-Cam 2 04-15-2008 08:06 PM
offsetting tools earl General Metalwork Discussion 6 05-03-2007 11:28 AM
offsetting tools earl General Metalwork Discussion 2 02-22-2007 03:14 PM
Offsetting Polylines tahlinc Tahlcam 0 10-08-2003 06:35 AM
