| G-Code Programing Discuss G-code programing and problems here! |
Im having good luck pecking my partoff tool, feeding down .100, then retracting .005, feeding down another .100, and so on. Right now, Im typing it in at the machine.There has to be a G-code for this, Deep drilling in X instead of Z,? or, deep grooving. Like: G?? X-.032 D1000 U.005 R0 F.003:??? help please.(Fanuc control, Hwacheon lathe) I only want to retract .005 to break the chip, I dont want to retract all the way out of the part. Any help would be greatly appreciated. Last edited by eject_21; 05-18-2007 at 02:07 AM. |
| On machines in my shop a G74 is for drilling or face grooving. G75 is the cycle for o.d. grooving, c-o, live tool radial drilling, etc. There are 2 different formats depending on age of machine. Newer ons all use a 2-block format. G75R.005 G75X-.02Z(OPTIONAL)P1000F.0025 R-value is the retract amount. P-value is the DOC before retracting. Example would peck .1 deep before retracting .005. Making P-value smaller increases cycle time, but breaks chips up better if they are causing a problem. On some internal grooves, I've made the peck depth less than the feedrate for maximum chip breaking. Older machines use a 1-block call. It has been a while since I programmed one of them so I won't give an example for fear it might not be right. It is similar to your example. I will give you the exact format Tuesday when I get back to work. HTH |
| What is the G code for Grooving? Not G75? | cjchands | Mach Software (ArtSoft software) | 7 | 04-22-2007 05:07 PM |
| acme with grooving tool 2d or 3d?? help | jone | Mastercam | 6 | 04-15-2007 06:41 PM |
| Fanuc G75 Grooving Cycle post processor | rk176 | FeatureCAM CAD/CAM | 3 | 11-07-2006 07:00 AM |
| .250 Dia x 22.00 deep ?? | Rekd | Machine Problems, Solutions , Wireless DNC, serial port | 10 | 02-25-2005 08:24 AM |
| Cutoff/grooving problems | july_favre | Mini Lathe | 4 | 07-30-2004 12:42 AM |
