Old 05-02-2007, 12:37 AM
nelsonrb4 is on a distinguished road
Question CNC Lathe G code G73 / G83
Anybody knows why some books says G73 is contour turning, while others say G73 is for drilling. If this G73 code is for contour turning, can you please explain its parameters?..
Old 05-02-2007, 08:30 AM
dcoupar's Avatar
What make and model of machine and control are you using?
Old 05-02-2007, 12:00 PM
Capt Crunch is on a distinguished road
G83 is for Z axis drilling, G73 is repeat pattern. it follows the same path every cycle and applies a new wear offset every time. this would be used when you have parts that are the same shape, just slightly different sizes. I use these on my 0i Control
Old 05-03-2007, 07:58 AM
adamant is on a distinguished road
I normally use G71 for conture turning........
G83 looks like a drilling cycle for live tooling.
But yes........G73 is for roughing a conture turning
Old 05-06-2007, 06:34 PM
pugsley is on a distinguished road
G83 is a deep hole drilling cycle where the drill returns out of the hole to the "R" position to clear the chips.G73 is a pattern repeat cycle and i think from memory "G74" is a drilling cycle not G73.
I would rather be riding my harley!!!
Old 05-06-2007, 10:38 PM
joecnc1234 is on a distinguished road
you can use G73 as a drilling cycle just omit the x move. It pecks without moving out to the r plane every peck, it moves out only the amount in the parameter for G73 clearance.
Joe
Old 12-30-2011, 11:24 AM
tanvon's Avatar
tanvon is on a distinguished road
Fanuc Pattern Repeating Cycle G73
This cnc blog post fully explains the Fanuc Pattern Repeating Cycle G73
Fanuc G73 Pattern Repeating Cycle - CNC Blog
tanvon malik
http://www.visinia.com (CNC Programming Blog)
Old 12-30-2011, 05:50 PM
dcoupar's Avatar
This thread is 4+ years old. I think he's making parts by now.
learning g code or cad-cam code output? slow_rider G-Code Programing 3 02-27-2010 08:48 PM
looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft troyswood Ability Systems - LPT Indexer and G-Code 2 12-24-2006 09:21 PM
cam to g-code for cnc lathe slow_rider General CNC (Mill and Lathe) Control Software (NC) 0 10-21-2006 01:16 PM
CNC Lathe Threading G-Code HELP>>>> vtech99 Coding 2 08-26-2006 03:30 AM
fanuc 11 lathe g-code bobcor Fanuc 3 08-20-2006 02:16 PM
