Old 04-26-2007, 09:16 PM
williamglassII is on a distinguished road
Help programming G2, G3 partial circle blends, radius
I am looking for information on how to find the X and Z cordinates when programming a blend or radius for a turning center. I have the equations in the Machinery's Handbook, and understand them, but cannot figure out how to use them in referance to our shops prints. For instance. I have a pin that has two OD's. One is 1.400 +- .002 to 1.450 +- .005 the radius starts 1.000 from face of pin and the pin is 4.000 inches long. It has blended radii between the step of r.120 each (G3 to G2 respectivly). I am told that I need to find the Chord/Chords to figure out how to program the z and x cordinates (absolute programming) but with this information I don't know how. The equations I have tell me that I need to know two of these things to find this... The radius (which I know), the chord (which I need), the angle, the length of the arc, or the hight of the arc from the chord. I am using a Cincinnati Hawk with an Acramatic 2100 control 'Siemens'. The above example given was only an example, I'm trying to understand the concept of programming partial arcs without the use of a program. Although most programs i've seen need two of those numbers to figure out the arc too. I hope any of what I said makes any sense to someone, any help would be greatly appreciated. My e-mail is william_glass1978@yahoo.com. Thanks.
Old 04-26-2007, 09:54 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
I'll try to make you a drawing of what you need and post a pic later. One thing that you have to remember with Lathes is that your working in Diameters not Radii. So with that said everything in Z is Double in X.
Also you will need to use Tool Tip Compensation unless you want to spend wasted hours fudging around with your program to get the geometry on the part correct.
In the Tool Offset Geometry Page you will see X Z R T
X= Geometry Position part Center Line
Z= Geometry Position Face Z0
R= The Radius of the Tool Tip Insert ANSI CNMG432= .0312 Tip Radius
T= Tool Tip Designation 0-9 (for an O.D. turning tool this would be set to "3" and I.D. Boring Tool it will be set to "2") There should be a Chart in the Programming Manual
G42 is for O.D Turning Toward the Spindle
G41 is for I.D. Boring Toward the Spindle
Example a 1 inch diameter with a .1 45 Degree Chamfer is as follows.
O0001
G0G40G80G99M5
G28U0W0M9
M1
N1(TURN)
T0101M8
G50S2000M39
G96S500M3
G40G0X1.125Z.1
X0
G42G1Z0F.006
X.8
X1.0Z-.1
Z-1.0
X1.125
G40G0Z.1M9
G97
G28U0W0
M30
Example with a radius of .1
O0001
G0G40G80G99M5
G28U0W0M9
M1
N1(TURN CNMG432)
T0101M8
G50S2000M39
G96S500M3
G40G0X1.125Z.1
X0
G42G1Z0F.006
X.8
G3X1.0Z-.1R.1
G1Z-1.0
X1.125
G40G0Z.1M9
G97
G28U0W0
M30
Hop this helps.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 04-27-2007, 05:30 PM
I think I understand. My company thinks that g41 and 42 are evil so the nose comp is programmed by hand. That's ok, it's made me very quick and good with fractions to dec. :-) I think this is stupid, but I'm not high enough or willing to change thousands of programs to add this. I'm still a little confused on the radius though. I don't have to know what the chord of the arc is? Chamfers I have pat. 45's are easy double X,Z. All other angled chamfers I think are found by (Side "B" / tan of angle "b"), then just take the numbers and make them X and Z moves. Thanks again.
Old 04-27-2007, 09:49 PM
tobyaxis's Avatar
Moderator
G41/G42 are way better than the extra math that will have done without them, LOL. A Program should Match the Print to make edits easier plus less programming/tweaking to get it right the first time.
Believe me on parts like this for Lockheed Martin you better have the Right Geometry because there are 600 shops out there that are waiting for you to make a critical mistake.
G41/G42 = Friends
Name:	knuckle .75-10 .5 hex 2.jpg‎
ID:	36311   Click image for larger version
Name:	knuckle .75-10 .5 hex.jpg‎
Toby D.
Schwarzwald
Old 04-27-2007, 10:24 PM
You have to be a masochist to choose to do it by calculation . Get a cheap and simple 2D drafting program; I use a version of AutoSketch I bought in 1987. Just draw your diameter lines and the two circles that correspond to the fillet radii, move them around until the circles blend then zoom in and read off the coordinates.
In the picture I put Z zero at what I think is your 1" point so these coordinates have to be shifted to suit. The X are part coordinates, you can figure the tool nose rad correction if you're not permitted to use tool comp.
Note in the picture the circles don't blend but on the AutoSketch screen they did.
Old 04-28-2007, 04:52 AM
Talking Giggles and laugh
I guess I am sort of a Massocist, I really wish to know how to trig/Geom. it out. I guess I feel if I can do this, I Really know how to program it. :-) Peac to all and thank you to toabyaxis (my friend the evil machinist) and geoff (Dat's too easy!! Espc when my shop does everything the hard way!) P.S. If either of you need a setup operator, I would be glad to fill that position!!! (Not an ad, just a desperate act!) Peace to all and have a great weekend.
Old 04-28-2007, 04:56 AM
WOW, You have helped me the most!! Thanks!
Old 04-28-2007, 08:44 AM
gar gar is offline
gar is on a distinguished road
070428-0727 EST USA
williamglassII:
If I understand your question correctly, then the procedure is fairly simple.
In the cross-section you have two parallel lines spaced 0.025" apart. This is from (1.450-1.400)/2 = 0.025. Where the two radii meet is 1/2 of 0.025 = 0.0125 .
Now we have a right triangle to solve. The hypotenuse is 0.12 and the long side is 0.12 -0.0125 = 0.1075 . The short side is 0.0533 . For reference the small angle is 26.3843 deg.
In the Z-axis on the lathe the distance between the two arc centers is 2 * 0.0533 = 0.1066 .
The radial or X position of the center of the first arc is 1.425/2 + 0.1075 = 0.8200 from the centerline of the pin. The second arc center position is 1.425/2 - 0.1075 = 0.6050 .
The first arc Z center is -1.0000, and the second is -1.0000 - ( 2 * 0.0533 ) = -1.1066 .
Check my math.
You may need to put a very short straight line at the intersection of the two radii if the controller has a problem with this intersection.
Old 04-28-2007, 09:02 AM
Okay, hard way. Although you only need to be a wimpy masochist because it only needs geometry not trig. The two fillet radii are the same.
gar got in a few minutes ahead of me and did the description in words, here is a picture. We did the calculation a bit different; gar mentions angles so I guess he is more of a masochist than me .
Old 04-28-2007, 09:11 AM
gar gar is offline
070428-0905 EST USA
Geof:
I did it first with the Pythagorean theorem, then double checked with COS and TAN.
  #11   Ban this user!
Old 05-27-2007, 09:59 AM
g-codeguy is on a distinguished road
geof and gar- You guys must be wimps! LOL. When I started programming, it was for punch presses. No computer software. Everything had to be figured using 90 deg. formulas. Thank God for computers, hey?
Just joking. From what I've seen so far, you guys know your stuff.
  #12   Ban this user!
Old 05-27-2007, 10:48 AM
I used an abacus and slide rule when starting. And scratched drawings on birch bark with a piece of charcoal.
Partial arc positiverake Fanuc 3 01-10-2007 09:29 PM
programming radius/ help needed integrexe410 Mazak, Mitsubishi, Mazatrol 6 12-11-2006 12:14 PM
Circle instead of radius Prboz Mach Mill 7 10-01-2006 09:13 PM
Ramping on part, partial circle with a G3 and 4" cutter ? iMisspell G-Code Programing 10 07-20-2006 02:19 AM
Programming lathe with radius numbers mudwhump BobCad-Cam 1 06-07-2004 07:14 AM
