Results 1 to 7 of 7
Thread: coordinate system
    Mar 2007
    Thai Land
    coordinate system
    Dear all,
    I'm a newbie of G_code programmer, so any body can explain detail about coordinate system that are using in CNC Milling machine. How many type of coordinate system using in CNC machine? What type of coordinate is refered to in G_code or whereis reference coordinate in G_code? Thank in advance all.
    Registered Jarwalcot's Avatar
    Jun 2005
    JR Walcott
    Georgia Machine Tool Resources, LLC
    Dec 2003
    If you do a search of Cartesian coordinates it will give the basis of the coordinate system.
    With a mill the coordinate directions assume the Spindle is moving in all three directions, In fact in most cases the Spindle Z is the only one that moves, the table therefore has to move in the opposite X & Y direction to obtain the correct XY spindle referenced direction.
    If you have used an osilloscope you may alread be used to the coordinate directions, where the X moves from - to + left to right, Y moves - to + upward and Z moves away from you in the direction of the image.
    If you use this method by standing in front of the mill looking down on the table, the above directions will apply.
    But remembering that the spindle probabally does not move in the XY means that the table will be programmed to move with the +- reversed in order to achieve the correct spindle orientation.
    In a gantry mill etc, the spindle usually moves in all three directions and the table is stationary.
    You write the program both the same way, the reversal direction is taken care of in the machine.
    Registered dcoupar's Avatar
    Mar 2003
    Kieth,
    Which CNC mill? Which control? Fanuc is different from Fadal, etc. Tell us what you're working with, and we can help.
    Dave
    Dec 2003
    Quote Originally Posted by dcoupar View Post
    Although Fanuc do not dictate what is used, it is up to the MTB or Retrofitter to get it right.
    Moderator tobyaxis's Avatar
    Jan 2006
    Quote Originally Posted by kiethnt View Post
    Dear all,
    The Machinery's HandBook has them in the 26th and 27 Editions. YOu can also download a trial CAD or CAM Software to get used to Programming using the Axial XYZ's.
    Cheers!!!!!!!!!!
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Jul 2006
    us
    JR Walcott
    very nice. is the 1st and 2nd class papers available for download.
    tks
    craig
    1. Using 3d Coordinate Conversion On A Vf4
      By renglish in forum Haas Mills
      Last Post: 02-02-2007, 12:04 PM
    2. Coordinate system problems
      By R.thayer in forum LinuxCNC (formerly EMC2)
      Last Post: 11-19-2006, 03:36 PM
    3. preprogrammed coordinate programming?
      By Tristar500 in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 03-02-2005, 09:43 AM
    4. coverting from Right-hand to left-hand coordinate system
      By eltonr in forum General CAM Discussion
      Last Post: 10-14-2004, 09:40 PM
    5. User coordinate system?
      By HuFlungDung in forum OneCNC
      Last Post: 04-18-2003, 10:26 PM
