Old 04-08-2007, 09:21 AM
Chipload's Avatar
Chipload is on a distinguished road
Fanuc 0M G10 programing
Would like to write a program to clear all offsets in the machine. I do not know what other addresses a person would use to make this work.
Old 04-08-2007, 12:02 PM
sluggo is on a distinguished road
you could use G90 G10 L2 P1 X0 Y0 Z0 (B0, A0, or C0) then copy it and change P. P1 = G54, P2 = G55.
Old 04-09-2007, 07:39 PM
dcoupar's Avatar
If your machine has the User Macro B option, you could write a macro to clear all of the offsets.
Old 04-10-2007, 09:17 PM
Chipload's Avatar
I got it
Clear work offset G54:
G10 G90 L2 P1 X0 Y0 Z0
Clear tool offset H1:
G10 G90 L11 P1 R0
G10 - Data input
G90 - Absolute value
L2 - Work offset
L11 - Tool offset
P# - offset number
X - value of X axis
Y - value of Y axis
Z - value of Z axis
R - value of tool length/radius
Works pretty good. In about 3 seconds, all the offset are reset to Zero. No more unexpect values when I set up a new job.
Programing help with fanuc 10T adaptaflex Fanuc 3 02-16-2007 08:11 AM
Programing book mikeh Laser Engraving & Cutting Machines 0 03-03-2006 05:47 PM
CAM programing kenlambert G-Code Programing 1 02-03-2006 12:03 AM
Acramatic 2100 to Fanuc Series Oi-ma Programing BUD B General CAM Discussion 0 11-15-2005 03:38 PM
CRC programing with an old Fanuc 11M controller Moparmatty G-Code Programing 4 02-08-2005 09:10 AM
