Old 03-29-2007, 07:52 PM
marrieche is on a distinguished road
vARIABLE #3006
Could somebody explain the use of variable #3006 and what does the number after the equal means, for example #3006=101
thanks
Old 03-30-2007, 08:45 AM
dcoupar's Avatar
I assume you're talking Fanuc?
Variable #3006 is similar to #3000, except #3000 generates an alarm, and #3006 doesn't. The number is arbitrary (3000 can use from 1 to 200), so I assume 3006 has the same limit.
When the macro executes the following line, the message in parentheses is displayed on the CRT and the macro execution stops.
#3006=102(JOG TOOL TO Z ZERO)
The operator can then perform the requested task (in this case, go to Jog/Handle, and move the tool tip into contact with the z-zero of the part), then go back to AUTO/MEM and hit Cycle Start. The macro continues from the next line.
Hope this helps.
Old 03-30-2007, 02:47 PM
Thanks, for the information
Miguel
Old 03-30-2007, 10:10 PM
skullworks is on a distinguished road
Exclamation Warning !
Hope this helps.
Please note that program execution stops - BUT SPINDLE WILL REMAIN ON unless an M5 is in the preceeding line. This is used like the MSG command in non FANUC controls.
Also I think it is a bit value ( 1 or 0 ).
The purpose of #3000 is to allow user defineable alarms - hence the ability to apply a code# value.
I will post examples later.
Greg
Old 03-31-2007, 08:31 AM
dcoupar's Avatar
Greg,
You're right, the spindle remains on, as does the coolant, air blast, or whatever else the macro program turns on.
My example, #3006=102(JOG TOOL TO Z ZERO) was from a proven, working macro, so it apparently isn't a bit value, because the 102 works fine. They're just user-definable messages as opposed to #3000's user-definable alarms.
Dave
variable accuracy thekm Open Source CNC Machine Designs 10 09-11-2006 02:01 PM
IF variable = bla THEN do this ELSE do that ? iMisspell G-Code Programing 21 07-30-2006 10:57 PM
Variable transformer bdillard General Electronics Discussion 8 02-20-2006 09:33 PM
LoadProgram into variable? murphy625 CamSoft Products 3 04-12-2005 10:14 AM
variable speed??? turmite General Electronics Discussion 14 03-27-2004 01:26 PM
