Old 03-19-2007, 10:41 AM
Mike Mattera's Avatar
Gold Member
Mike Mattera is on a distinguished road
Can the Haas do "G54P1" style offsets.
On the Fanuc you can do a G54.1P1 for fixture offsets above G59. Does the Haas run this code the same way?
The Manual says G54-G59 then G110 - G129.
I'm writting a post and I'm looking for the simplest way to do this.
Thanks in advance,
Mike Mattera
Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
http://www.tipsforcadcam.com
Old 03-20-2007, 08:21 AM
dcoupar's Avatar
Mike,
Nope. Haas, in their infinite wisdom, decided to do it different than Fanuc, and they only give you 26 as opposed to 54.
What CAM system are you writing the post for? Maybe someone has already done this.
Dave
Old 04-02-2007, 05:42 AM
joecnc1234 is on a distinguished road
You can use G10L*P* to set work offsets where L1P1 IS G54 and I believe L2 P1 IS G110 P2 IS G111 ETC.
Old 04-02-2007, 08:27 AM
Originally Posted by dcoupar View Post
Mike,
Dave
Depends on the age of the machine, recent Haas can do way more than 26. The ones above G129 use a different command that is 'something' P. Look in their manual online.
Old 04-02-2007, 10:38 PM
dcoupar's Avatar
Well, he said HIS manual said G54-G59 and G110-G129, so that's what I went with. Too bad they didn't come up with a "Fanuc Compatible" work coordinate system setting.
Old 06-23-2007, 04:53 PM
cnc-king's Avatar
cnc-king is on a distinguished road
the newer haas models uses G154 P1 thru G154 Pxxx
G54 Thru G59 is still available
not sure if this is an option?
If you can ENVISION it I can make it
Haas "TL2 & TM2" thoughts pugsley Haas Mills 12 01-13-2011 07:33 AM
BattleAxe "aka" Ball and Chain "aka" the wife. ZipSnipe CNCzone Club House 48 05-18-2008 09:53 AM
"HACKING" the optional functions on the Haas control? AMCTony Haas Mills 16 12-03-2006 11:28 AM
Vertical system "jerks" and "bangs"?? REVCAM_Bob Servo Motors and Drives 5 06-12-2006 09:09 AM
Add "View New Posts" to "Main Menu" Mr.Chips Forum Questions or Problems 4 04-21-2004 10:54 PM
