| G-Code Programing Discuss G-code programing and problems here! |
I'm having a problem with a G76 on an 18-T controller on a Hardinge super precision lathe. My threads are coming out ok but the first pass is very deep. The format goes something like this.... G76 P---- Q---- R---- G76 X--- Z--- Q---- F---- Please tell me exactly what each of the parameters defines so I can figure out what the problem is. Thanks alot. |
If G76 isn't working for you try G92. It will allow you to taylor each cut right down to how many spring passes you want. Format is as follows: G40G0X.25Z.05 X.12 G92X.043Z-.05F.01041 X.041 X.039 X.037 X.035 X.034 X.033 X.0325 X.032 X.032 G40G97G0Z.1 G28U0W0T0 M1
__________________ Toby D. "Imagination and Memory are but one thing, but for divers considerations have divers names" Schwarzwald (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) www.refractotech.com Last edited by tobyaxis; 03-10-2007 at 05:23 AM. |
| G76 P---- Q---- R---- G76 X--- Z--- Q---- F---- If your first cut is deep your starting point could be small. I use .015 from the material for OD or ID. Mess with your Q's for first pass depth. .................The second Q is for first pass. You can cut threads so fast that I often just went with Q5 on both numbers. This cuts .001 per pass. Last edited by adamant; 03-10-2007 at 06:32 AM. Reason: I was wrong about the Qs |
P=02 number of finish passes 00 not sure what this one is........00 is fine 60 Degree of tool point normally 60 top Q= mininum cutting depth R= finnsih allowence.......small number is good R5 Second Q is the amount of fist pass. X= Major or minor depending on ID or OD Z=Leangth F=feed rate 1/number of threads per inch |
| This is how i set mine up it does not appear that you have a P in the second line "you may not have to have one but i always use it, its the highth of your thread the Q in the second line controls you first cut depth Q in first line is the amount per pass N9000 (1/2-20 OD THRD) G0G55T202 G97S400M3 G0X.55Z.1M8 G76P020060Q70 G76X.4402Z-2.14R-.0015P0620Q100F.05 G0X6.0Z8.M9 M1 M30
__________________ individual who perceives a solution and is willing to take command. Very often, that individual is crazy. |
| ID Threads | phoodieman | Daewoo/Doosan | 27 | 01-03-2008 08:33 PM |
| Need help with threads | Turk88 | General Metalwork Discussion | 2 | 07-27-2006 01:35 PM |
| New threads that are not new??? | turmite | Forum Questions or Problems | 1 | 01-27-2005 08:52 AM |
| npt threads | scubasteve | G-Code Programing | 13 | 03-16-2004 04:37 PM |
| Saving threads or parts of threads??? | flybynight | Forum Questions or Problems | 4 | 02-22-2004 12:19 AM |
