| G-Code Programing Discuss G-code programing and problems here! |
| Check to see if you have parameter 9937 bit #4 set xxx1xxxx. This can be for variables 149-199 & 531-999 Al.
| I am not sure which ones you mean by #1000 up, as far as I can tell the 18 & 18i show 100 to 199 and 531 to 999 for variables by option. Al.
| In MDI, key in #101=#4007, EOB, INSERT, and Cycle Start. You can then look at 101 in the MACRO variables and see the value of system variable 4003. #4003 is the active G code of the 07 group (G40, G41, G42), so you should see a "40" stored in #101. |
| AFAIK if you have macro option then you should have access to the system variables, read only. Active G codes, as mentioned, and servo positions etc etc. Al.
| Ok guys this is getting rough. I think I'm going to start from the bottom. I'm a beginner in this...I'll start with small programs before I get to macro functions and stuff like that. Thank you all for your help. Cheers George |
| Variables/Macro uses.... | theemudracer | Fanuc | 12 | 12-13-2006 01:45 PM |
| G65 local variables help | FanukRC | G-Code Programing | 7 | 07-25-2006 06:00 PM |
| Hitachi Seiki Seicos MYII control system variables | pieface | General CNC (Mill and Lathe) Control Software (NC) | 2 | 02-21-2006 12:45 PM |
| Need detailed information for system variables on Fanuc0m control? | Alf012 | General CNC (Mill and Lathe) Control Software (NC) | 4 | 03-03-2005 12:52 PM |
| Mori Seiki MF-T6 System Variables | EvilScooby | General CAM Discussion | 0 | 06-12-2003 07:32 PM |
