Old 02-13-2007, 02:47 PM
jorgehrr's Avatar
jorgehrr is on a distinguished road
Parameter changes
Hello everybody
I'm ready to start my journey with macro programming.
My Lathes Miyano's (Fanuc 18TB) need some parameter changes.
Does enebody know witch ones?????
Please help.
Cheers
Old 02-13-2007, 03:08 PM
Al_The_Man's Avatar
I have 9932 bit #7 (1xxxxxxx)for the 18M, I would assume it is the same for the 18T.
Old 02-13-2007, 04:10 PM
jorgehrr's Avatar
Thank you
I'll try it......
I know I have to test it with:
#101=1
What is suppose to happen if it works???
Old 02-13-2007, 04:13 PM
Al_The_Man's Avatar
You won't get an error?
the contents of local var. 101 will =1
Old 02-13-2007, 04:27 PM
jorgehrr's Avatar
Al-
I changed it, and test it (#101=1). I get an alarm:
Illegal addres imput.
Is this good news??????
Cheers
Old 02-13-2007, 04:35 PM
jorgehrr's Avatar
Al -
Thank you
I'll keep playing tomorrow.
Time for a cold one.
Cheers
Old 02-14-2007, 08:38 PM
theemudracer is on a distinguished road
dont put it inside of the ( ), if you are.
just
#101=1.
Old 02-15-2007, 05:23 AM
jorgehrr's Avatar
Right -
When I use 101=1; I get an alarm
If I do 101=1 I do not get an alrm.
Anyway now..Ican not found the macro soft key to be ablo to se my variables.
I think I need the help of Fanuc.
But if someone outhere has any ideas......
Thank you all for you replies.
George
Old 02-15-2007, 07:57 PM
Push the offset button and then press the right hand arrow soft key. It should be on this page as another soft key appearing.
Jon
Old 02-15-2007, 08:06 PM
jorgehrr's Avatar
Thank you,
I got it now.
George
0TC parameter for more memory? jani Fanuc 32 01-16-2010 04:44 PM
Fanuc OT parameter(s) erwin1958 Daewoo/Doosan 5 03-26-2009 10:36 PM
parameter fanuc om-d dlmusinage Fanuc 1 05-17-2006 04:54 PM
Mazak OP2 parameter xr135 Mazak, Mitsubishi, Mazatrol 0 05-17-2006 02:11 PM
L50 parameter write Bluesman General CNC (Mill and Lathe) Control Software (NC) 0 02-09-2006 05:49 AM
