| G-Code Programing Discuss G-code programing and problems here! |
| Before coffee answer: Give it to someone who knows that when they post questions on a forum that they have to include enough information for someone to answer it. After coffee answer: Depends. Do you have a control that takes step & direction signals? If so, use Mach3. If not, you may have to buy a control as well, and then it matters what kind of machine it is. -Jeff |
| I have a new hermes gravograph Trophy master and the software used is gravostyle. I would like to use for example, artcam which is a more useful 3d software than the one they are offering mean. |
| It Gravostyle will take G code, you are all set. I doubt it though. If you can find out how the software tells gravostyle to move, and it is step/direction through a parallel port, it should be easy. Use Mach. If it's not, you are probably stuck unless you want to strip off the controller and connect a new controller directly to the steppers. Probably at least $600-$700 to do it right. Look at Xylotex. Then use Mach for the software. -Jeff |
| Thank you for replying, much appreciated, but the problem is that i am not too familiar with g codes and stuff, i got this machine to engrave and then i realised i was able to do 2D wax models, my software only allows me to do 2D. But now i want to design 3D models. Now in the business i am in, artcam is really convenient. So if you can explain to me a bit more in detail where i can find the G codes and how do i apply the software to the G codes and when you mean i have to change the controller, is it the remote control. Thank you for your time. Chris
| Mazatrol Program into a G Code Program | fuzzman | Mazak, Mitsubishi, Mazatrol | 14 | 02-08-2010 03:55 PM |
| Example CNC machine Setup Sheet + program backup | lug_wrench | Machine Problems, Solutions , Wireless DNC, serial port | 4 | 10-14-2008 08:24 AM |
| getting program to machine | fourperf | Fadal | 7 | 03-16-2006 04:48 PM |
| Anyone got any basic examples of a program using a subroutine/program? | Darc | CamSoft Products | 11 | 10-08-2005 11:45 PM |
| Mits wire machine center program | turkgeltz | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 11-21-2003 04:22 PM |
