Old 01-16-2007, 02:10 PM
mzbik is on a distinguished road
Mazak Integrex 100Y Subspindle Milling Mode not working
I'm having trouble milling on subspindle on Mazak Integrex 100Y.
I'm probably missing some G and M codes ,or these that I use are misplaced.
I'm using Gibbs 8.0,and the post is not perfect for this machine.
Milling on Main Spindle works OK.
Below I'm posting tape code for milling operation on Main Spindle (working fine),and Subspindle (not working).
When I simulate tool path it works,but running prog,alarms out,
with message about B axis not locked.
Please take a look at my code ,and tell me what's wrong
Milling Mode Code Presentation on Main Spindle (working)
( OPERATION 7, HOLES )
( RGH_TURN_MAIN_SP )
( TOOL ID 6, 1. DIA. CENTER DRILL )
( #1 CARBIDE CENTER DRILL #002.152 )
( CS#9 - GATE1 )
( MAIN SPINDLE )
N134T0606.8B12
N135G53P1
N136M302
N137M200
N138G50W0.
N139G110C1
N140G0C0.
N141G97S2500M203
N142M250
N143B15.
N144M251
N145G125X2.694Y0.Z-3.467R1
N146G17
N147G0G98X0.Z5.66C0.M8M153
N148Y0.
N149Z2.5
N150G83X0.Y0.C0.Z-.5R0.F20.M210
N151C-120.
N152C-240.
N153G80G0Z2.5
N154Z5.66
N155G69.5
N156G30P1V0.
N157G30P1U0.
N158G30P1W0.
N159M9M154
N160M205
N161M1
Milling Mode Code Presentation on Sub Spindle (NOT working)
( OPERATION 22, HOLES )
( MAIN SPINDLE )
( CS#6 - XY PLANE )
( SUB SPINDLE )
N412T0606.15B18
N413G53P1
N414M300
N415M200
N416G50W#605
N417G110C2
N418G0C0.
N419G97S2240M203
N420M250
N421B180.
N422M251
N423G17
N424G0G98Z-2.5M8M153
N425G112M19S0
N426X0.
N427Y0.
N428G83X0.Y0.Z2.R0.F360.M210
N429G80G0Z-2.5
N430G30P1V0.
N431G30P1U0.
N432G30P1W0.
N433G28W0.
N434M9M154
N435M205
N436M1
Old 01-19-2007, 02:05 PM
JimW is on a distinguished road
Here's a spot drill cycle from an Integrex drilling on the main, side and sub. There are some G and M code differences, you might give these a try and see if it helps
(1/2 SPOT DRILL)
N14 T22022.0 B72
G53 (T32 COORD SYS)
G17 (XY PLANE)
M201 (MILL MODE)
G111
M212 (C-AXIS UNCLAMP)
G28 H0
G0 C0
M211 (C-AXIS BRAKE)
M302 (MAIN SPINDLE)
G0 G90 G98 G97 S3820 M203
M8
X2.638 Z1. C0
G83 X2.638 C0 Z-0.063 R0.9 F25.
G80
G0 X20. Z5. C0
M1
(1/2 SPOT DRILL)
N15 T22022.1
G111
G0 C0
M211 (C-AXIS BRAKE)
G19 G0 G90 G98 G97 S3820 M203
M8
X4.912 Y0 Z-1.308
G87 X2.528 Y0 C0 Z-1.308 R0.9 F25.
G80
G0 X4.912
G30 Y0 M9
G30 U0
G30 W0 M205
M1
(1/2 SPOT DRILL)
N16 T22022.11
G53 (T32 COORD SYS)
G17 (XY PLANE)
M300 (SUB SPINDLE)
G112 M201 (MILL MODE)
G110 C2
G112 M212 (C-AXIS UNCLAMP)
(G50 C#500)
G0 C0
G112 M211 (C-AXIS BRAKE)
G0 G90 G98 G97
G112 S3820 M203
G50W-#501
M8
X2.124 Z-2.766 C0
C0
C0
G83 X2.124 C0 Z-1.686 R0.9 F25.
G80
G30 Y0 M9
G30 U0
G30 W0 M205
M1
Old 01-22-2007, 12:57 PM
Thanks!
We are going to try it
mzbik
Old 01-22-2007, 12:59 PM
Thanks!
We are going to try it.
Mzbik
