Old 12-31-2006, 09:56 AM
redeft is on a distinguished road
z axis rising problem
Help!
After a few passes the z axis rises when it shouldn’t and it is a real pain. It seems to do it regularly after about 5 or 6 mm then up she goes again. Sometimes a little, maybe 1 mm or sometimes a lot, 5 to 10 mm.
I've replaced the worm gear etc. so I am quite sure it is not a mechanical problem.
The g code post is in multicam cnc and the files are quite large. I am cutting wax with a .003 bit from Bits & Bits.
I’ve got a used cnc express mill from Microkinetics. The motion controller is
OptiStep Plus-PC™Motion Control Card For PC/AT, 1-4 axes
See it here : http://www.microkinetics.com/optistep.htm
and the drive rack is here http://www.microkinetics.com/pdfmanuals/DriveRack.pdf
Has anybody ever encountered this problem before?
