| G-Code Programing Discuss G-code programing and problems here! |
I have a 1984 Ikegai FT20-U with a Fanuc 6T-B. I've been reading the manuals, and they are kind of hard to understand. What is the difference between G92 and G50 for setting workpiece zero? Does this control have work offsets such as G54? The manual doesn't list it, but could that have been added? I am in the leaning process, so this may be a stupid question. Please forgive my ignorance. |
| Lathes may often use a different gcode system than mills, and on some controls, you can actually set (via parameter) which gcode system you intend to use. So, mills usually use G92 as a coordinate system shift, whereas lathes will use G50 to do the same thing. The two codes are not interchangeable (within one gcode system), it will be a case of one or the other in your particular controller. You just have to find out which system is in effect
| My Fanuc 6T-B manual doesn't list G54-G59, so as far as I know Work Coordinate systems weren't available on that model... so: More than likely, your machine is set up to use Standard G-Codes (as opposed to Special G-Codes B). This means that you'll use G50 Xn Zn Sn to set your X/Z zero for each tool and maximum RPM (for CSS mode), and G92 for a simple turning cycle. You might try to MDI a G50 S500 and cycle start to see if it causes an alarm 010. Also, you can check Parameter #7, bit 5. 0=Standard G code is used, 1=Special G code B is used. Good luck. |
| Yes, you'll need to program a G50 (or G98) block for each tool. If your control is set up for special G codes, use G98. My guess is, it's not, so use G50. Most (if not all) Japanese machines came over with standard G codes, if my memory serves me correctly. No advantage one over the other, just use the one that works. |
G50 is used on older lathes to set the tools. The Ikegai I worked with all the tools were set from the Home Position Relative to the Work X and Z. Another way was to set a known position and program G50 X0Z0. Then write your program from there. This would usually be the axial center of the X and Face of the Z. It is really up to you and what your comfortable with. Personally I prefer setting my tools Relative to the Home Position. BTW G92 is a Threading Canned Cycle on a Lathe, not Work Positioning. Threading Cycles are G32 G76 G92
| From what I can gather from the manual after many hours of studying is to load a turning and facing tool, take a light cut on the face and outside diameter. Zero the display, then go back to machine zero. Record the readings on a piece of paper, and then program G50 Xwhatever Zwhatever and thet will be your zero point for the entire program. Your reference tool offsets will be zero of course, and then you touch off all your other tools to set their offsets. Doesn't say you have to re-enter G50 and your zero coordinates after every tool. I looked through a couple old programs in the memory, and they didn't have a G50 at every change, so maybe I won't have to do that. There is a chart in the Fanuc manual that states G92 as special G code and special G code C. It also says workpiece coordinate shift is a basic option?? Is adding that as simple as changing a parameter or is it more complicated than that? I can see where that would be very useful, but I guess I could do it just as easily with a G50. Well I kinda got a bigger problem now. I think the rotary encoder on the turret is going out, so it may be even longer before I really get this thing going. ANybody know how to test the encoder? |
| You have two options for using g50. You can set it once as you have just described from the manual, or you can set it for each tool. The difference is that setting once may cause tool offsets to be large numbers since the offset will be relevant to your datum tool. This can cause problems when you have to alter tool offsets due to large numbers being easy to forget if you have to enter the whole number. Setting G50 for each tool will result in all your tool offsets being zero initially, which makes it easier when resetting your offset after an insert change because you simply set it back to zero. With either method, it pays to have the program send the machine home at the start, move to your start position, then redefine G50, so if the machine gets moved manually it will pick up the correct position. regards, Oz |
#10
| This is an old Ikegai Program for a Fanuc 6T. The starting point is set far away due to the uneven saw cut. Also this is a Safe way to start programming until you get more comfortable. O0086 (IKEGAI FANUC 6T) (TURBINE SPLINE 27SPL) (GM 200 TH200R4) (MATERIAL=4140) (PILOT=1.375D) (ID=.814D) (OAL=) (BLANK=) (DRWNG=SPLINEA.CAD) (OP#1) (DATE 2/10/03 PGMR TJD) (DATE REV 2/10/04 TJD) (T1=CNMG432 VALINITE SV330 T3) (T2= DRILL .75D COB STUB 135SPT) (T3=DNMG431 SECO FF1 CM T3) (T4=B-BAR 1/2 CCMT21.51F2 TP1000 T2) (SECO CARBOLOY) (JAWS=400 PRESS=200) (CYCLE TIME=MS) G0 G40 G97 G99 M5 G28 U0 W0 M9 G50 S2000 M39 M1 N1(REMOVE SKIN/R-FACE/TURN) G28 U0 W0 T0100 G50 X(RP) Z(RP) M8 G96 S700 M3 G0 G42 X3.99 Z.3 T0101 G1 Z-1.3 F.01 X4.05 F.015 G0 G40 X4.1 Z.2 G72 P10 Q15 W.005 D400 F.008 N10 G0 G41 Z0 N15 G1 X0 F.004 G0 G40 X4.0 Z.1 G71 P20 Q25 U.02 W.002 D850 F.01 N20 G0 G42 X1.0 G1 Z0 F.0025 X1.325 F.003 G3 X1.375 Z-.025 R.025 F.0025 G1 Z-.75 F.004 X2.75 F.0035 X3.975 Z-.9141 F.0025 G1 Z-1.08 F.004 N25 X4.1 F.0035 G0 G40 Z.1 M9 G0 X(RP) Z(RP) T0100 G28 U0 W0 G97 M1 N2(DRILL) G28 U0 W0 T0200 G50 X(RP) Z(RP) M8 G97 S400 M3 G0 X0 Z.2 T0202 G1 Z-2.25 F.0075 Z.05 F.2 G0 G40 Z.1 M9 G0 X(RP) Z(RP) T0200 G28 U0 W0 G97 M1 N3(F-FACE/TURN/U-CUT) G28 U0 W0 T0300 G96 S900 M3 G0 G41 X1.5 Z0 T0303 G1 X.625 F.004 Z.05 F.015 G0 G40 X4.1 Z.1 G70 P20 Q25 G0 G40 Z.1 (U-CUT) G1 X1.3755 Z-.725 F.05 Z-.7555 F.0025 G4 U1.0 G1 Z-.75 F.003 X2.8 F.0035 G0 G40 Z.1 M9 G0 X(RP) Z(RP) T0300 G28 U0 W0 M5 G97 M1 N4(R-BORE ) G28 U0 W0 T0400 G50 X(RP) Z(RP) M8 G96 S400 M3 G0 G40 X.75 Z.1 T0404 G71 P40 Q45 U-.02 W.002 D320 F.0075 N40 G0 G41 X1.214 G1 X.814 Z-.1 F.003 Z-1.3 F.005 N45 X.75 G0 G40 Z.1 M9 G0 X(RP) Z(RP) T0400 G28 U0 W0 G97 M1 N5(F-BORE) G28 U0 W0 T0404 G50 X(RP) Z(RP) M8 G96 S650 M3 G0 G40 X.75 Z.1 T0404 G70 P40 Q45 G0 G40 Z.1 M9 G0 X(RP) Z(RP) T0400 G28 U0 W0 G97 T0 M30
#12
| To put it bluntly Fanuc Books SUCK. Try this one. It can be found on Amazon.com and explains everything in ENGLISH. http://www.amazon.com/Computer-Numer...e=UTF8&s=books This is by far the Best for Learning Lathe and Mill G-Code Programming. Tool Stations 1,3,5,7,9,11 are all O.D Turning Threading, and Grooving Tool Stations 2,4,6,8,10,12 are all I.D. Drilling, Boring, I.D. Grooving and Threading. Post the Program You have and I'll walk you through it.
