| G-Code Programing Discuss G-code programing and problems here! |
| You need the EIA programming book for that one. It's not in Mazatrol unless it was output as an EIA conversion.... but it doesn't look like that. What part of it are you not understanding? The "G" and "M" codes?
__________________ It's just a part..... cutter still goes round and round.... |
| I looked at your G-code program and can't help you with that. You should probably be working with the Mazatrol side of the control for this part. If you see me a copy of the print I could tell you which would be better. How many axis's are you trying to program? That's makes a difference also. |
| I skim read through the program you post. It seem like it do some contour groove on the cylinder and drill a hole at 35deg angle, and all that variables(#) are for calculate the length of the work piece position at 35DEG. Everything is pretty much straight forward G-code. I can't help you much since I don't have machine to test out.
__________________ The best way to learn is trial error. |
| Thank you for your attention to my problem. I am not understanding the tool number code. The line: T025025.01 B27 What is it? I think what here is tool change command. The tool number is 25 and tool length offset number is 25. Is it right? I think what the ".01" is turret number maybe. Maybe B27 is angle of the spindle orientation for tool change ... ????? About EIA programming book. Where its possible find? |
#10
T025025 Means Tool 25 Offset 25 .01 No Clue B27 could be the B Axis Position for Milling?????? I do have a question for you though. Why are you (or someone else) trying to program this machine EIA/ISO when Mazatrol will do this for you? I have been told that regular 2 axis Lathes and 4 Axis Mills are fine to Progam EIA/ISO but not anything else. Personally I have heard nothing but Nightmares about trying to program these machines with anything other than Mazatrol. Did you or the company you work for hire a Contract Programmer to do this for you? Try these guys, maybe they can help http://www.griffobros.com/
#12
